Question about Refrigerators
I have an Active Smart E406B and have a problem where it begins to beep with the green lights on the panel flashing and then when any one of the control buttons inside is pressed the beeping stops but then ranging may be from anything between 1 minute or even a few hours it again starts to beep and back agin when a button inside is pressed it goes away. Very annoying specially at night. also of late I have noticed the cooling in the fridge section is less in the upper shelves of the fridge. The upper the shelf the lesser the cooling. Freezer which is in the bottom works ok.
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Posted on Feb 16, 2008
SOURCE: Model E372b Fisher & Pykel - Beeps with Fridge Door closed periodically-Higest shelves warm lower down freezes things
First I would like to say thanks for all the information on the Fisher-Paykel active smart fridge freezer problems. This was a lot more useful than their customer support help line… After a week of hanging on for ten minutes without any answer I had a look on the net and found your site with descriptions of similar problems so I decided to investigate further
I have a Fisher Paykel fridge freezer (model 402B in the UK) about three years old. Although it didn’t seem to be as cold as normal, the first sign of a serious problem was when it started making a rattling or knocking noise from the freezer compartment. Looking inside it was obviously iced up solid and the noise was probably the fan catching the ice. So first thing I decided to try was a days de icing after which everything seemed ok except the green indicator light was now flashing about once every second.
Two weeks later it was badly iced up again so the problem was still there. At first I suspected the fans (which I could never see actually working). I disconnected one and tried it with a 6v torch battery and it spun ok. It was then I realised what was happening - the fans cut out whenever the door is opened so they are always stopped if you look inside.
A closer look at the aluminium heat exchanger(behind the plastic panel at the back of the freezer section) showed there was some kind of heater element clipped along the bottom with feed wires at either side. Obviousely part of the automatic de icing systems. It’s a bit tricky but there an electrical connector plug at the top and disconnecting this enables you to unclip the element and remove it (except that in this case one wire had been trapped at the wrong side of the coolant pipes when they had been fitted so it had to be snipped to get it out). Once out a circuit test showed there was no circuit through the element. So cutting into the two shrouded connections at each end of the element revealed some little components inside which I now know are “Thermal fuses”. One of these had “Blown”. There was a number on the side: - DF 72S which Google revealed is a thermal fuse set at 72 degrees. Although these are listed as spares in all sorts of places non was convenient to the UK. So I found a similar component at Maplins Electronics (R14) set at 92 degrees for just 69p! The reasoning being that the other thermal DF 72S fuse was still ok and the slightly higher use temp at the other end would still blow before anything melted!
By the way you cannot solder these things in so its best to use miniature screwed “block” connectors plus a good covering with insulation tape.
After putting it all back together its now been working for a month and no ice build up… The green light did still flash for a while but went out once the temperature dropped too normal freezing level.
Total cost of replacement parts was under £1 but it took a bit of time find the problem.
Posted on May 12, 2008
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
  • 30 Answers
SOURCE: fridge beeping
the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Posted on Jun 08, 2010
Fisher and Paykel Active Smart fresh food compartment indicator is blinking continuously.
flashing lights and beeps indicate a component failure. Count the beeps and provide details here.
Jul 16, 2016 | Fisher and Paykel Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Our upside down fridge/freezer started to beep. Upon opening the fridge the thermostat lights on the back was flashing red then green then red again anyone help?
This is a connection issue between one of the temperature sensors and the electronics, the plugs on the sensors need to be removed and cleaned with contact cleaner and you need to make sure that the contact are pushing firmly against the circuit boards, there are 2 control units, one behind the fridge beside the compressor and one in the back of the fridge which you get to by simply pulling the middle rear panel out after removing the shelves, just be careful as you can damage the plastic.
Mar 05, 2012 | Fisher and Paykel Active Smart E522B...
F&p beeping,pressed green button beeping stoped but now fridge and freezer not cooling greenlights flashing?
HI,IF YOUR REFRIGERATOR IS BUILT WITH DIGITAL TEMP CONTROL ,PROBABLY THE PROBLEM COULD BE A BAD SENSOR ,BAD COMPRESSOR,OR BAD CONTROL BOARD,IF YOUR FRIGE IS LESS THEN A YEAR OLD MAY BE UNDER WARRANTY ,CONTACT THE FACTORY TECH DEPARTMENT FOR DIANOST AND SERVICE..
Feb 21, 2011 | Fisher and Paykel Active Smart E522B...
Fridge beeping
Jun 07, 2010 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
