Question about Hotpoint Washing Machines
Hotpoint WDL520 - Fabric Conditioner Drawer full
Hotpoint WDL520 - Fabric Conditioner Drawer is always found to be full of water at the end of a wash programme. If a small amount more water is added it empties itself. Hotpoint engineer found 'no fault' so I would like to be better prepared before I call him again! Washing results are quite poor, so suspect Conditioner is leaking or being washed into machine during the wash cycle.
mumma_1
  • 903 Answers
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Posted on Nov 03, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
Posted on Jan 02, 2009
SOURCE: My Zanussi ZWF1430W won't take fabric conditioner
Sometimes the drawer gets blocked with congealed fabric conditioner and or old soap powder, try removing the drawer and giving it a good wash. An old toothbrush is useful to get in the small areas. To remove the drawer: Pull the drawer out as far as possible, there is a small depression on the left hand side at the top of the drawer, about the size of a fingertip press the depression to release the drawer, and pull the drawer out. To relocate, line the drawer up, and place the long thin piece of plastic on the left hand side in the corresponding slot in the top of the drawer opening, you might have to kneel down to see it and slide the drawer in, you might have to press the depression again to pushe it home.
Posted on May 12, 2009
  • 24 Answers
SOURCE: fabric conditioner drawer not emptying
take drawer out to clean. take it apart and clean top bottom back and front, sounds like theres a blockage stopping the conditioner from syphoning out'
Posted on Aug 05, 2009
beltronic205
  • 1466 Answers
SOURCE: my machine won't take the fabric conditioner. It
ok try removing the soap tray and cleaning. it works by filling to a certain level then allows to empty by way of Syphon effect, you can check this easy with a glass of water fill it as far can go does it drain away? It should , if it does then try with softner on wash should now be ok, providing The valve coils are okay..you can let me know.
Posted on Jun 24, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
The fabric conditioner drawer is always full of water at the end of the cycle, i have tried cleaning it and running the machine empty but nothing has worked.
fabric conditioner drawer is always full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2011 | Washing Machines
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Fabric conditioner drawer full of water!
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Water in Fabric Conditioner Drawer
Mar 30, 2007 | Hotpoint WMA50 Front Load Washer
Fabric Softner Drawer
Hotpoint Aquarius WMA42 Front Load Washer
a 4 THUMBS rating is appreciated for answering your FREE question..
Feb 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
