My computer (Windows XP-SP3) states that "Windows Management Instrumentation is missing or moved". How can I reinstall these services?
    President:
  • 1,194 Answers
Hi Albertobrum,
Try this Link to download Windows Management Instrumentation.
If this also doesn't solve the problem then reinstalling Windows XP sp3 is advisable.
Thanks for using Fixya.
Good luck and have a nice day.
Posted on Jul 09, 2010
  • 1 more comment
  • albertobrum Jul 10, 2010
    Hi Rango, thanks for your answer.
    However, that link is for a download for SP1 installations.
    I have SP3.
    Consequently, it gave me an error explaining that the fix was for a previous version, so it did not work for me.
    Can you please give me any other idea - or a download of a fix for SP3 installtion?
    If not, can you detail how I can re-install Windows SP3?
    Thanks, regards
    Alberto+
    10/July/2010-11h40m GMT
  • Ranglo
    Ranglo Jul 11, 2010
    To see how to re-install Windows XP Service Pack-3, visit this Link to see the steps involved.
    As states in the link it is advised to first Repair the operating system. If repairing, does not solve the problem then Installing the Windows XP is advised.
  • albertobrum Jul 11, 2010
    Hi Ranglo:
    1 - You made a mistake in sending me for the second time a link for a SP1 installation.
    Your second link took me to exactly the same download as your first link, namely:
    -file to download: Q319322_WXP_SP1_x86_ENU.exe.
    2- Anyway, I HAVE MY PROBLEM SOLVED: I researched the net and used a script of
    commands I found in www.pcreview.co.uk/forums...
    So. please forget this enquiry of mine.
    Thanks anyway, regards
    Alberto+
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Ordinal 266 missing
Download Windows XP Service Pack 3 on another computer,
and burn to a CD, or copy to a USB memory-stick.
Take the CD or memory-stick to your computer, and Install SP3 on your computer.
Then, access http://windowsUpdate.microsoft.com to get all the post-SP3 updates.
This will install the newest DLL files, with all the correct ordinal-points (including #266).
Oct 09, 2009 | Microsoft Windows XP Professional With...
USB works under BIOS, doesn't plug'n'play under WinXP
Seems u r having plug and play problem.
When the second problem appeared? after the upgrade?
Some weird things like this, exists with SP3.
Does Windows ask u to install them?
Check whether the PnP is enabled from the BIOS.
U can try installing your chipset driver (Update).
Go to action menu and Click on Show Hidden Devices. Go to Hidden devices and check whether there are entries related to usb with yellow marks. Parport,Mountmgr (non PnP). etc. Check whether you have any Viruses.
Important :
Check whether these services are functioning properly.
Go to Device Manager
Click On - Services
Plug and Play (Automatic-Normally) Service
and Such services as PLFlashDeviceIoControl Service, Portable Media Serial Number Service, Windows Management Instrumentation (Set to Automatic) and Windows Management Instrumentation Driver Extensions (Start it). They are the people who are responsible and caused these errors. Double Click an set each one's Recovery options.
Then go to Event Viewer and check System (ans Application) for specific erroneous entries.
Did u do a system restore. Anyway if you have upgraded u can't of cause. U could try that. Check whether ur usb root hubs are functioning. U have to upgrade drives for XPSP3. There are many compatibility issues.
Try the latest chipset drive.
Try removing these.
Then reboot and check.
If this solution works or helped you, please kindly RATE the answer.
Wish you luck!
Thanks.
Lasitha
Jun 28, 2009 | Microsoft Windows XP Professional With...
WMI Error
I'm pretty sure you have a failing hard drive. Try dowlnloading diskeeper 2009 trial & see what it shows for fragmentation of the drive. Run the program & defrag the drive. If that doesn't help you can look for a program called tuff test & check the drive that way. That's the sure fire way to find out. If the drive passes tuff test then back up your important stuff & reformat & re-install the os. Use google to find tuff test. Good luck!
May 03, 2009 | Computers & Internet
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
WMI Has encountered a problem and needs to close
Symptom
When you attempt to start the Windows Management Instrumentation (WMI) service, you may receive the following error message, and the service does not start:
Could not start the windows management instrumentation service on local computer.
Error 1068: The dependency service or group failed to start
Resolution
First, verify the number of dependencies attached to the WMI service. This can be viewed by running the following command from Start, Run:
CMD /K SC QC WINMGMT
The output should exactly as given below.
[SC] GetServiceConfig SUCCESS
SERVICE_NAME: winmgmt
TYPE : 20 WIN32_SHARE_PROCESS
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 0 IGNORE
BINARY_PATH_NAME : C:\WINDOWS\system32\svchost.exe -k netsvcs
LOAD_ORDER_GROUP :
TAG : 0
DISPLAY_NAME : Windows Management Instrumentation
DEPENDENCIES : RPCSS
SERVICE_START_NAME : LocalSystem
*See attachment*
The only dependency is the RPCSS service, and it does run by default whenever you start Windows. If you have any other dependencies listed, then it may be the causing the problem. To remove the additional Dependencies, follow this:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Before you modify the registry, backup the registry key by exporting the corresponding branch. Also, see here to learn how to perform a complete registry backup.
Click Start, Run and type Regedit.exe
Navigate to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\winmgmt
Double-click DependOnService, and set it's Value data to RPCSS
Close Regedit and restart Windows
If this fails, you will need to do a repair installation..
Hope this will be helpfull
Thanks & Regards
NANDU
Mar 06, 2009 | Microsoft Windows XP Home Edition
NTLDR missing while clean install
Well Bart CD that everyone downloads has some nice utilities on it, some free some not.
You have to be carefull using such utilities as they can cause more harm then good...
You now have to reinstall windows before you can apply sp3. Sp3 is not bootable and bart CD doesn't have windows install of any kind on it... Reinstall windows with your disc then browse to your cd and double click on sp3 to update...
Hope everything works out now....
Please rate this solution if it helps... Thank You...
Nov 03, 2008 | Microsoft Windows XP Professional With...
Window XP Home SP3
go to control panel, administrative tools, computer management, services and applications, services, look for themes - if it is not started, start it - if it works, goto the properties of the theme service and set to automatic
G'luck
Oct 24, 2008 | Computers & Internet
Windows XP SP3 very slow to shutdown with Clean Slate 5 installed
Services has been altered Try to install a fresh copy of windows Then type msconfig on run and go to services find a small check box hide all microsoft services
Oct 22, 2008 | Fortres Grand Corp Clean Slate
DELL COMPUTER
You are using windows xp service pack 1
Apr 26, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
