Question about Frigidaire Electric Dryer
DRYER WILL NOT START MODEL FSE747GE
Shut door, select cycle & turn start switch. Dryer will not start. I can hear a relay engage on the motor control board simultaneously with the start switch & it will hold as long as the start vswitch is held in the on position. At the test points on the control board I read 4.0 volt. ????
I have tried another motor and control board but same symtom Also I have ohmed door switch(2 positions), timer control, control thermostat, high limit thermostat, thermal limiter. I have verified 115 volt @ timer &
240 volt @ motor thermal. All wiring and connections look good.
I don't have access to a service manual. Any ideas? Thank you.
( This is my personal dryer)
  • 11,896 Answers
Looks like you have got power to the motor. Did you ohm the motor itself? It may have stuck internal brushes
Posted on Jul 09, 2010
  • 1 more comment
  • kevin544 Jul 09, 2010
    I have tried another motor, but same results
  • Nate Stansfield
    Nate Stansfield Jul 09, 2010
    Did you switch out the relay?
  • kevin544 Jul 10, 2010
    I replaced the electric reversing dryer control board.
Dryer stooped in mid cycle and now will not start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
https://www.youtube.com/watch?v=sTRP6kHqAFs What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Feb 22, 2016 | Maytag Centennial 7.0 Cu. Ft. Super...
My Bloomberg DVDs 17540 dryer stopped in the middle of the cycle and now it does not turn on. I purchased this dryer 2 month ago and I barely used it as I like to dry most of my cloths in open air. But I...
Mar 16, 2015 | Dryers
Dryer wont start.
Oct 30, 2014 | Dryers
My GE Dryer Model #DJXR433EG1WW will not turn on.
Oct 12, 2014 | Dryers
I have a Hotpoint Dryer NVLR333ETOWB, I opened the door mid cycle, to check on load, make sure it was drying, I shut the door, and when I turn the start knob, all I get is a buzz, and the dryer does n
Sep 29, 2014 | Dryers
Kenmore 70 series dryer shut off in mid cycle and will not restart when I push the start button. any suggestions?
Sep 14, 2014 | Dryers
Kenmore 970 c85092 00 dryer
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Aug 19, 2014 | Kenmore Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Kenmore Whirlpool Dryer Won Start Easy Fix
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Frigidaire  Electric Dryer Logo
55 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
