Question about Dell Computers & Internet
When I boot up my PC (Dell XPS 400) and select my user icon, a ''Windows Installer'' pops up and a ''ScanSoft PaperPort 11'' window appears trying to install this ScanSoft program. I then get a pop up saying ''Feature you are trying to use is on a CD-ROM or other removable disk that is not available. I click OK and get another window that says Insert the 'ScanSoft PaperPort 11' disk and click OK. I don't know what disk this is on and don't have it to insert so I click Cancel. I then get a window that says ''Error 1706. No valid source could be found.'' I click Cancel again and it just continues in a cycle no matter what I do until I use Ctl, Alt, Delete and click Delete Task in the Applications tab. Any solutions?
  • 518 Answers
The pc is looking for the driver of the program,if you have the program disc ,reloading will clear off the message, but if no disc,go to control panel,open =load,remove icom go down list til you find program, then remove
Posted on Jul 09, 2010
Nuance PaperPort won't install on Windows 7 64-bit Toshiba dual Pentium processors
This problem occurs due to corruption of data on your computer.
You must reinstall the operating system, you have to check the hard disk to eliminate physical damage on it.
Apr 11, 2014 | ScanSoft Nuance ® PaperPort® 11 Full...
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
When ever i start up computer a Windows Installer pops up request for SCANSOFT PAPER PORT 11 installation from disk that I do not have. Could you help
Hi
Go to start menu, choose RUN, type MSCONFIG and then go to start up and uncheck this program. It will never pop up again.
Mar 06, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
Cant install on windows 7
use windows compatibility mode.
1 - right click over the app installer
2- click on properties
3 - go to the tab compatibility
4 - check the box in ( Run this program in compatibility mode )
5 - Select Windows XP (service pack 3)
6 - check the box ( Run this program as an administrator )
7 - Click apply
8 - Click OK
Feb 25, 2011 | ScanSoft PaperPort Deluxe 8.0...
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I operate Windows 7 and installed Paperport 11. I want to scan documents from another program, like WORD. In the printer drop down you are supposed to see: Paperport Black & White as well as Paperport...
This type of information (different ways to scan) come through the software. I'm pretty sure you will not be able to do this by the (add printer) method. I would uninstall the Paperport driver from your computer, then reinstall, and try to use the "advanced" method to see if it will allow you to add those two. I have found if scanning ability shows up in one Microsoft Office product, it will show up in another. Plus, my photo processing program will show the same ability.
Nov 30, 2017 | ScanSoft Nuance PaperPort 11 for PC
Describe your scansoft paperport deluxe 9 windows Vista printer drivers Problem Can not install why
Hi there and welcome here
Take a look here :
http://reviews.cnet.com/document-management/scansoft-paperport-deluxe-v/1707-3522_7-30787056.html
It does not describe windows Vista, so I think it is not compatible with windows Vista, so there is 2 thing you can do :
1. you can see if it runs in compatibility mode, and you do it in this way : Highlight the program icon on the desktop or in the start folder, choose properties, select the last tab, choose compatibility mode with windows xp and try to open the program
2. If it is not working maybe you can upgrade to a newer version, for that you have to go to the product homepage . Normally you find a link in the program where you can go to the product homepage.
Hope this can help
Have a nice Christmas over there
Please rate my answer
Dec 22, 2009 | ScanSoft PaperPort Deluxe 9...
Paperport selection on printer, but item does not print to paperport
Hi Try this solution: Go to your printers and faxes control panel and right mouse on say the paperport colour image printer. Now select the Paperport tab and you will find where the images are being sent! Probably in the bowls of documents and settings; all users bla bla. Change this to where you want them to go. I changed mine to drop into the MyPaperPort Documents folder for ease of use.Do the same for the black and white printer if you like.
Jul 09, 2008 | ScanSoft PaperPort Deluxe 8.0...
Computers & Internet Logo
342 people viewed this question
Alun Cox
