Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Motor has to be cranked alot to start and then when you push up on the throttle for more power it runs just above an idle , and dosent rev up all the way
  • 84 Answers
Your carb. might be out of adjustment. There is a rod and another rod with a spring on it going from the carb. 2 an arm on the side of the motor. With the motor running, push the arm a little towards the carb. If it revs up, its out of adjustment, if not, you have a dirty or bad carb. Clean or replace the carb. If that doesn't work, your keyway might be cut or broke. The keyway is what keeps the motor in time so everything works together. Like a timing chain or belt on a car. Good luck.
Posted on Jul 10, 2010
I own a 1990 3cv it increases revs from idle to around 3000 once it has warmed up if I stop the motor for a bit then start it again the revs will do the same I have cleaned out the carbs and replaced
You mean the revs come up even if the throttle is left in idle?
If yes: it means your idle runs too lean AND the carbs aren't balanced ( one gives more air than another )
Unscrew all the idle mix screws 1/2 turn
To balance, remove 1 spark plug lead, check the rev falling.
Replace the lead and remove another one. Check the rev fall etc...
Regulate the carb opening so that all the cilinder disconnects give the same rev-drop.
Dec 20, 2014 | Bikemaster 1986-1990 Yamaha Fj1200...
My 2000 GMC/jimmy suv starts up but doesn't respond or rev up whenI push the accelerator pedal
Look for where the throttle cable connects at the throttle body. If you can move the throttle plate here and get the engine to respond, then the cable is either broken or disconnected at one end or the other. Any other situation doesn't seem likely.
Aug 22, 2014 | 2000 GMC Jimmy
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
1997 saturn sl1Trouble starting
check the crank shaft sensor its behind the starter they r cheap
Jul 01, 2010 | 1997 Saturn SL
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
Stiff accelorator pedal
It is either the cable that goes from the pedal to the throttle body, or the throttle plate is sticking.
Mar 30, 2009 | Hyundai Motor 1998 Accent
Yumbo motor scooter
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls confirm that it uses a two-stroke 50CC engine. Additionally, your description "It refuses to rev beyond idle speeds." could indicate several conditions:
  • throttle up above idle speed, engine stalls/dies - fuel related issue, fuel starvation, clogged jets, nozzles, too much 2T oil, contaminated fuel (water). Basically a carb rebuilt;
  • throttle up above idle speed, no change in engine RPM - mechanical problem, possible broken accelerator/throttle cable, stuck plunger in carb, detached needle valve;
  • throttle up above idle speed, engine backfires/dies - electrical issue, check CDI, stators, trigger/pulse, their physical state/mounting, electrical connections;
  • throttle up above idle speed, engine hesitates/flat spot - air/vacuum issue, check rubber coupling from carb to intake manifold, blocked or absent air filter.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 28, 2008 | 2004 Yumbo Dakar 200
Idles fast
Most likely an air leak/vacuum hose problem. There could also be an issue with the throttle body base gasket. The 4.3 engines are known to rev a little high but a small air leak can make them rev really high when they should not.
Oct 18, 2008 | 1992 Chevrolet S-10
Starving for fuel
Check the system pressure aginst spec in manual.
Jul 13, 2008 | 1997 Nissan Pickup
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
286 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
