Question about Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le
I have a Robo Laser RB01001 and the light or beam is too dim to see after about 4 ' Replacing the batteries don't make a difference.
  • 10,865 Answers
Hi. Did u open the front and turn on the remote to activate the laser ? This is what it usually takes to get the beam out there. J.
If this doesn't work, return it. J.
Posted on Jul 09, 2010
I need a manual for a Robo Lazor model RB01001 and calibration instructions
This would be an interesting device to wear on your wrist - perhaps entering the question into the correct forum might yield a result?
Jul 10, 2016 | Watches
Driver side low and high beam on but dim. Passenger side low beam normal but high beam on and dim
I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - ‎4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - ‎4 authors
Jan 04, 2016 | Cars & Trucks
When i put my key in the switch it wont turn on
Make sure its In park . Recharge battery first
Feb 13, 2015 | 2002 Jeep Grand Cherokee
Left hand headlight works &right hand side headlight works but both not always come on main beam
Hi, Tony if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Low beam headlights don work High beam headlights do
http://www.body-kit.co.uk/pdf_files/headlight-troubleshooter.pdf
Honda CBR125R Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR125RW Owner Manual
Feb 27, 2014 | 2005 Honda CBR 125 R
Robolaser rb01001
The lock lever must be stuck. Check the locking lever.
Jan 21, 2014 | Measuring Tools & Sensors
Headlight went out on low beam on a 2000 honda shadow
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
3. Worn, chafed, or broken wires in the light circuit.
low beams don work but high beams do Honda Tech Honda Forum Discussion
2005 honda shadow headlight repair
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Jan 11, 2013 | 2000 Honda VT 750 C2 Shadow
Brake lights work but are very dim
It can be loose wiring or issue with bulb or the battery is weak or brake light socket getting short somewhere.Car lights getting dim,there are many such common issues noticed.I will share some familiar help links,related to your problem.
Click the link below:---2004 Dodge Ram: High Beam Light is DIM? http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
----------Ford Odometer Dims intermittently http://schematicsdiagram.blogspot.in/2012/07/ford-odometer-dims-intermittently.html
---------Turn Signals Don't Work When Brakes Are Applied? http://schematicsdiagram.blogspot.in/2012/04/2005-gmc-envoy-turn-signals-dont-work.html
Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
----------- No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
----------- Brake lights not working on 1989 BUICK REGAL? http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
These will help.
Thanks.
Nov 06, 2012 | 1999 Ford Contour
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Logo
378 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
