Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Dishwasher is filling with water but not washing
My Indesit slimline dishwasher fills up with water, it then stops completely after a couple of minutes and both the wash and rinse lights flash repeatedly.......the water sits in the bottom and the pots are unwashed.
  • 641 Answers
SOURCE: Water filling does not stop
Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and as well to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Good luck !!
Posted on Jun 24, 2006
SOURCE: Indesit dishwasher sump keeps filling up with water when turned on
I had a similar problem every time i bailed the sump out by hand and turned the machine back on it would fill the sump or just shut off.
Having spent ages checking various site it boiled down to one of three things there is a thermostat switch underneath they are know to go on the indesits and cost next to nothing to replace
second cause and most probable is to take machine outside before you do this front cover below front door removes to give access to pump you ll know it the pump because it has a pipe rinning into it and one out on my indesit i turned it upside down and got really easy access to it comes of easily take it to pices bit by bit really easy probably need small allun key depends on model check put for foreign objects , spinx blackpool rock etec etc only kidding it might be a bit of plastic or something that stop the spindle turning freely inside the pump if you find anything clean put back and off you go if pump is knackered you can get them off the web for 4.95
last but not least is the problem that mine actually had in the end and the easiest to fix `water pressure` if there is insufficient water pressure the machine regognised this and activate a shut off valve the machine lights flash you can reset the programme but it still does nt work. take the water pipe off the back put it into a bucket and open the valve you ll now what good pressure looks like mine was poor when i took the adjacent kitchen unit out it transpired a shut off vavle had been placed on the pipework the vavle had never been opened fully by the plumber and was restricting the water supply . take your time dont rush and be methodical take advantage of a local parts supplier ash them what most repairers will do first. it can be very rewarding to find that a/ you can do it and b/youve saved 60 or 70 quid in the process.
ps never mess with the machine whilst connected to the mains or spiky hair might come free with the repair and do take the machine outside or you ll have water evrywhere trust me
Posted on Jan 17, 2008
SOURCE: Indesit IDL 40 Slimline flashing lights
I have the same problem as well. I have tried adding salt, but I still get the flashing lights.
Does anyone have a solution?
Posted on Mar 01, 2008
SOURCE: indesit dishwasher type no. LS12-EV03
go to this
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Dishwashers/D63.pdf
mine has stopped filling with water!
corefchaos
Posted on Sep 02, 2008
SOURCE: Indesit IDL40 Dishwasher
eror ao8
Posted on Sep 06, 2009
D41 slimline dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 13, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Door won't shut
Is there sufficient spring reaction? Spring weak or broken? Has latch or catch moved? Is there adjustment on either? Is there debris stopping mechanism from working? Has door dropped?
May 11, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
Check to see how fast water is entering the dishwasher.
They work on a timed basis with a float switch being a safety.
You may want to check how the water gets into the dishwasher and  then see if there is plugging somewhere.
Feb 16, 2008 | Indesit 24 in. D61 Free-standing...
Dishwasher filling up then stopping
is it going into the wash or just filling and thats it? if it fills and does nothing straight after it is probably the wash motor is jammed or seized. if the d/w starts to wash then stops it may be the heater is faulty.
Feb 16, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit IDL40, 2nd & 3rd light flashing
It can also be that the pressure is too week. If you look a tthe manual it mentions this exact symptom. I know because i ve a similar issue. cheers
Dec 13, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
DI 67 S fault
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
Sep 28, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
42 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
