Question about AOpen AK75 (91.89X10.001) Motherboard
AK75 Well! got my comp past the searching for server, only to get stuck on searching for Kernel! I had it booted until I put my ethernet card in, whats it doing? thanx iain6312
My mother board is mercury. Some numbers is there like p19 45gcm v1.0a 15-v33-011098
Posted on Apr 20, 2008
Server boot
ntldr is part of the Master boot Record (MBR) it is used in conjunction with other files to allow the OS to interact with the Kernel.
you can copy the MBR record but it is specific to each PC so your options are rebuild server or restore from a backup I would recommend back up as all additional settings will be applied still.
Dec 23, 2013 | Dell PowerEdge 750 Server
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Dell PowerEdge 2450 Server issues
FIrstly reseat all removable components in the system and retry
Second remove all DIMMS except one. try again
I not then remove this DIMM and put in another one. This is to test for a faulty DIMM thats hanging the POST
TRy these things and see if you get further
Mark
Aug 18, 2009 | Dell PowerEdge 2450 Server
Can't connect to WPSM54G after configuring it
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Apr 16, 2009 | Linksys WPSM54G Print Server
A Dell PowerEdge Server will not start. The server goes through the boot sequence, but after a while there is no activity. OS: Windows 2000 server
This sounds like a RAM issue or a strange peripheral problem (when the driver loads it kills the system). Try running the system on only 1 stick of RAM at a time, swapping until you find a bad stick. Also, clean the contacts off with a pencil eraser before putting them in.
If this doesn't help, pull PCI cards one by one (except for the RAID card, if any - but do pull out, clean and put back in the RAID card just in case it's a contact issue) at a time until the system boots (or just try safe mode, but this won't tell you which one is a problem).
If the system still can't boot, then I'd say it's probably the motherboard.
Jan 06, 2009 | Dell PowerEdge 2600 Server
Unkown SCSI Problem
Hi Fatoil ,
Have you tried another SCSI port , another SCSI card , another SCSI drive , swopping if it is card problem or drive or both problem ?.
If you have a spare SCSI hd , plug it in to same port and see if it works . Swop to another port and see if the spare SCSI hd works. Swop to another SCSI card and see if spare SCSI hd works.
All this elimination will narrow down the problem .
SCSI cards are not expensive ,.
old working SCSI hds don't cost you anything if you have them.
Sending out the server for servicing will cost you.
I presume you don't have a maintenance contract for this server .
If you have , get them down to settle it .
If you don't , after you settle this matter , make sure you get a maintenance contract for all your critical servers / equipment.
Maint Contracts seem expensive when nothing breaks down. However , when they do , it makes every worry go away.
Good luck,
David
May 26, 2008 | HP CC3310 (a9863a) Server
MOTHERBOARD
That is your computer trying to boot from your network adapter.
Check in the bios the boot order.
Set it to
  1. CD/DVD Rom
  2. IDE0
  3. IDE1 or whatever you want.
Also check the first page to see if it has actually found your hard drive and cdrom. If not check the cables are connected. If they are both on the same cable then check the jumpers on the drives to make sure you have them set as Master (hard drive) and slave (cdrom) or both set to cable select.
Apr 18, 2008 | AOpen AK75 (91.89X10.001) Motherboard
Booting from cdrom
To,
Tinker12.. Yes , I want to wipe the sytem clean. No data wish to save.
Feb 19, 2008 | Compaq ProLiant ML530 Server
Dazed and confused - unknown system restart
First off, take the message at its word: restart the machine, go into the BIOS and disable all power saving. Also, turn off ACPI if it's on.
Jan 28, 2008 | Computers & Internet
AOpen AK75 (91.89X10.001) Motherboard Logo
70 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
