Question about Vizio VX20L 20 in. LCD TV
I have hum bars on my televisions just the vizios i have 3 other televisions and they are perfect
    Problem Solver:
  • 10 Answers
Hum Bars are caused by electrical interference. If you have other equipment hooked to the vizio such as a VCR, try unhooking the VCR and hooking cable directly to the tv bypassing the VCR. If you have a Cable signal amplifier hooked up that also can cause interference if it is going bad. Some tv's can handle the negative interference better than others. You could also try moving another tv into the room where the vizio is and see if that gets hum bars as well. In this situation the process of elimination is the best method. If it goes away using a different tv then it could be the vizio. If a VCR is the problem your best bet it to leave it unhooked. If an amplifier is the issue try it without the amp hooked up. Now with the change over to digital you may not need an amp and can leave it disconnected. If Not you can easily replace the amplifier. If these don't work I would suggest contacting your cable provider so they can properly assess the electrical problem and assist you in fixing the issue before causing and damage to your equipment.
Posted on Jul 10, 2010
Why does my vizio d65u-d2 tv sound goes out and a pop up at the top (channel 720 time bar graft wide)
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 26, 2016 | Vizio Televison & Video
I have connected a good mans sound bar but have no sound from tv
sadly we have no idea what you connected to the set from the sound bar .My Vizio works perfectly with an audio cable set
Jan 16, 2016 | Televison & Video
My Vizio flatscreen 60" HD tv background music sound overpowers talking. How can I lower background music? When no background music, the sound (talking) is perfect.
This is typical of sound systems that come with TVs, especially flat screens. You need to look into purchasing an external sound system, such as a sound bar or a surround sound system. That way you can have better control of background/voice ratios.
Jan 04, 2016 | Vizio Televison & Video
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
Humming sound vizio
99 percent of the time the humming can only come from a defective powerboard, before it dies, you should consult your warranty. Otherwise you can order the parts and replace yourself.
Jun 01, 2009 | V, Inc. VIZIO RP56 Rear Projection...
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VX20L 20 in. LCD TV Logo
173 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
