Question about Grilling
Have a charmglow 810-7310s grill, and the burner on the right center won't light ? my grill is 1.5yrs old and never had an issue before now
  • 10,865 Answers
Hi. Take out the grill and the heat deflectors and check out the right center burner. IT may be cruddy or clogged or have a spider nest in it or worse. Mine was rusty and deterioriated and I had to replace it. Charmglow has all of the parts available if you need them. J.
Posted on Jul 09, 2010
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
I have frost on the line coming from my gas tank to the burner on my Charmglow grill. Do I need to replace the flow valve. If so, what part number do I order and from where? Thanks, John
You need to replace the grills Hose/Regulator Assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. They run about $30.00. Take your old one with you for comparison purposes.
To avoid this happening in the future. Whenever, you turn the tank valve OFF and it comes time to turn it back ON, turn it ON VERY, VERY SLOWLY (Slow motion, slow). Doing it that way, won't lockup or blow the gas line regulator. It wasn't your fault, John (unless you didn't read the Owner's Manual). The new OPD tank valves, will shoot to high a pressure sometimes and either lockup the regulator or cause a small leak, like it did with yours. That's where the frost was coming from.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Brinkmann Charmglow Stainless Steel LP...
My propane tank is full, but none of my 3 burners come on, 1 does very slightly but then goes out, help! thanks
Turn the propane tank valve to OFF. Disconnect the hose from the tank and wait 5 minutes. Then, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank first and turn the burner knob to high. Does the flame height look as it should? I f it does, light the remaining burners the same way, one at a time. Do all the burners burn as they should? If so, you solved the problem. If not, you need to replace the grill hose/regulator assembly. You can get one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Hope this helps and Happy Grilling!
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
The gas from the tank is not flowing to the burners on my Charmglow grill
to solve this problem, turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank and turn it to it's highest setting. Does the flame height now appear to be normal. If so, light the remaining burner(s) the same way. If everything has returned to normal, you've solved the problem. If it hasn't, then more thank likely your Propane Tank is empty or the regulator/hose assembly may need replacing. If so, you can purchase one at any home center or hardware store that sells gas grills and accessories. Juts tank your old one with you for comparison purposes.
Apr 03, 2011 | Brinkmann Charmglow Stainless Steel LP...
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
New grill (Charmglow 810) unusual (to me) line of flame
The line of flames you describe is the cross over between the burners. You can light one burner and the rest will light from the coss over flames.
Nov 25, 2008 | Brinkmann Charmglow 810-7400-S Propane...
Grilling Logo
129 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
