Question about Brother MFC-465CN InkJet Printer
Brother MFC-465CN printer. Need a fix for error 46.
Help please, urgently need a fix for error 46 (ink absorber pad is full and needs replacing). Machine is a Brother MFC-465CN all in one printer.
  • Brother Master
  • 379 Answers
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
MACHINE ERROR 46
Hi
This code indicates that the internal ink absorber box is full and requires replacement I have included a link below that explanes what you need to do to fix this
MFC 215 error 46
Aug 02, 2014 | Brother Office Equipment & Supplies
Error 46?
The ink absorber pad is full and needs replacing.
Please contact Brother Customer Service.
Feb 21, 2011 | Brother MFC 210C All-In-One InkJet Printer
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
Jan 26, 2011 | Brother Office Equipment & Supplies
Error 46
The error 46 indicates that the ink absorber pad is full and needs to be replaced. According to their site here, you will need to have an engineer replace it for you, although I bet you could purchase a new one from their store.
Jul 29, 2010 | Brother Office Equipment & Supplies
Troubleshot 46 on mfc-240c
Error code 46 means that your ink absorber pad needs to be replaced. According to Brother, only an engineer can do that, but you can get more information from them by contacting Brother support:
http://www.brother-usa.com/Support/
Click on "Send us an Email" and tell them your printer's model number, the error code, and whether or not your machine is covered by a warranty.
Jun 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
I am receiving "Clean Unable 46" on my printer MFC-240C ....
Hi terri_robin
Click on the following link
Look for the title Error messages
Select LCD display on the printer
Look for Error 46
Looks like you need to replace the INk Absorption Pad.
Hope you have warranty still
http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/faq/faq_top.htm?reg=eu&c=eu_ot&lang=en&prod=mfc240c_all
Good luck
luciana44
Dec 01, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
I have a Change Unable 51 Error Message on my Brother MFC-260c MFC and it says to refer to User's Guide, how4ever there is no error code to match this in the guide. HELP!
hi karn..you need to disasemble your printer and clean your Maintenance unit....the coz of this error 51 is usually you are using competetor ink and then you have reset the counter (error 46) ,after you reset it, you need to change ink absorber if not it will bank those waste ink in the ink absorber and after it is full the waste ink have no place to store and it will jam the mantenance unit and the worse case it the ink maybe spoil other part of the printer go and find engineer  asap if not you need to replace new unit....
Mar 09, 2009 | Brother IntelliFax 1860C Plain Paper...
Brother MFC-465CN InkJet Printer Logo
1,779 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
