Isuzu Master
- Posted on Jul 09, 2010
Re: How do you take the grille off of a 1996 isuzu...
Trooper
See Figures 3, 4 and 5
Fig. 3: Front grille assembly-1984-94 Trooper
Fig. 4: Front grille assembly-1995-96 Trooper
Fig. 5: Retainer clip used to secure the front grille
Raise the hood and support it with the prop rod.
On 1981-94 models, remove the retainer screws from around each
headlight.
Remove the retainer screws from the corners and center of the
grille.
Using a small prytool to press the tab on each of the grille
retainer clips at the top of the grille upward while pulling the grille
away from the radiator support.
When all the tabs have been released, lift the grille up slightly
and out to remove.
To install:
Engage the lower portion of the grille into the radiator support.
Carefully push the grille toward the radiator support, making sure
the retainer clips align with their respective mounting hole. Once all
the holes align, press the grille and retainer in until it clicks into
position.
Install the retainer screws from the corners and center of the
grille.
On 1981-94 models, install the retainer screws around the
headlight.
Hope helps (remember rated this).
Testimonial: "THANKS very much this was very helpful.charles"
