Question about Fedders X Chassis A6X08F2A Air Conditioner
WHERE IS THE DRAIN?
WHERE IS THE DRAIN ON THIS WINDOW UNIT? IT SEEMS TO BE PLUGGED UP & IS DRAINING INSIDE.
  • Fedders Master
  • 43,501 Answers
It simply drains to the outside... you just need to tip the unit back more so it runs outside...
heatman101
Posted on Jul 12, 2010
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
My Kenmore window ac unit cools ok but makes a clicking/clacking sound while it runs. The cooling fan turns properly and it drains outside but has started to drain a little inside-it is angled to drain...
From everything you described, it sounds like more water than usual is collecting in the drip fan. Despite the unit draining out the rear drain hole. Check the drain hole to make sure it is totally clear and not partially clogged. A pipe cleaner works well to do this. Be sure to turn the unit OFF & unplug it, before working on it.
Hope this helped you and tanks for choosing FixYa.
Aug 15, 2011 | Kenmore 76100 Wall/Window Air Conditioner
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
The air conditioner is pouring water on the floor!
Sounds like your water drain line is plugged. There should be a bundle of wires tubes and a drain hose that goes through the wall to the outside unit. The water drain hose should split off outside and drain on the ground. You should check that the drain hose is not plugged or kinked somewhere. The hose must also slope downwards from the inside unit to where it drains outside. You can check if the hose is plugged by blowing into it if you can reach the hose outside. You should be able to easily blow through the tubing back into the house. I have done this with this type of unit at night (determined to get it working), and was able to get it to start draining properly. Before I got it to start draining, I had the same waterfall that you are seeing. The unit had been off all winter. Hope this helps.
May 23, 2010 | Fujitsu 24C1 Air Conditioner
Icing of the fins of my lg aircondtioner indoor unit
Check/clean intake air filter and condenser fins,as well as be sure condensation drain is clear as well. Sometimes if not the right angle, moisture remains inside unit rather than draining outside, or wherever your drain is, make sure it's clear and draining well.
Feb 03, 2010 | LG Electronic Window Air Conditioner
Roof air not draining and leaking inside coleman unit
there are 2 drains on most units one each side about 6 inches back from the front of the unit - they are white plastic and have a small hole in the side - they may be clogged - happend to mine - used a paperclip to clear out now work fine - good luck
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Water/condensation is backing up in the bottom of the unit and overflowing into the house.
The drain in the condensate drip pan is clogged. Locate it and clean it out.
Charlie
Aug 14, 2009 | Samsung AS1293L Air Conditioner
Kenmore AC 75085 Not draining properly
is the drain plugged? is the unit tilted away from the house slightly?
Aug 09, 2009 | Kenmore 75085 Air Conditioner
Water not draining out the back
Humidity is where the water comes from. If humidity is low, very little if any, water.
Jun 23, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Fedders X Chassis A6X08F2A Air Conditioner Logo
145 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
