Question about Proview PL926WBi 19" LCD Monitor
How to relace the belt?
Belt broken on a sears 139.53664srt
All power is good, heats up but drum won't turn. Hear humming noise after pushing start button. Relaced motor,thermal fuse and thermistor. Still nothing. Checked door switch. Any other suggestions?
Betty,
When you replaced the motor, did you also replace the belt? If you had not said that you already replaced the motor, I would have suggested that the belt was broken.
Jun 09, 2015 | Kenmore Dryers
95 dakota turns over but no start?
check to see if the cam shaft is turning (broken belt/chain)
Jul 31, 2014 | Dodge Dakota Cars & Trucks
Mower will run and pto will engage bet heard a snap and it will not move
you have broken your drive belt relace it looking carefully how it is routed
Jun 02, 2014 | Garden
Remove front panel
It was a broken dryer belt. Called Sears. No help ay all. No parts in the sears store.. Called Winklers Appliance 3705 Transport St., Ventura, Ca. 805.642.5103. Brought them the dryer belt. $ 18,95 . They told us what to do. Sold us a belt and we were fixed in 30 minutes at home, by our selves.
Mar 19, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Belt broken
Appliance stores, or appliance parts stores.
If you wish, you can also buy online at "Sears Parts".
If you will type in "appliance parts" or "Sears parts", many , many places sell these, and you can order them.
You will only need your model number in most cases.
Be Blessed
Feb 09, 2013 | Frigidaire Dryers
Hi I have broken a drive belt on my Subaru Lancaster 3 litre (year 2000} I have the new belt but cannot see how to remove the engine cowling so as to relace the belt and make necessary adjustments. It...
You may need more than a belt replacement; the link below will show the characteristics of Subaru engines and the H-6 is listed as an 'interference' engine, meaning that when the timing belt breaks, it is possible for the pistons and valves to collide which can result in bent or broken valve stems and/or damaged pistons. In this case, it is wise to have a pro examine the engine and replace the belt.
It is also possible to damage this engine by improperly installing the new timing belt.
Some of the details may be at odds with your specific model but the mention of this engine being an interference engine is enough to give one pause-
Subaru details
Dec 24, 2010 | Subaru Legacy Cars & Trucks
How long is the deck belt for a craftsman 42" deck
You must have tractor model number to find exact parts. There are many different types of mower decks. If you have your craftsman model number, you can go to www.searspartsdirect.com and find the sears part number. If you don't have your broken belt, to find size, it might be good to buy one from sears. Then when you get the belt see if there is a normal belt number on it to record. If not take your new belt to store to match it up to a power equipment belt. For example Tractor usually stocks a nice supply.
Jun 30, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My Sears 19.5 hp lawn tractor will not move foreward or reverse. There is a squeeling noise and smoke coming from the cutting deck. Help!!
It sounds like your drive belt is broken. Look under tractor and see if the upper belt is broken.
Good luck
roundo4
Aug 13, 2009 | Garden
Washer does not agitate, everythiung else works fine.
hi there.......you havent stated whether this is a top laoder or front loading automatic...so im assuming its the latter.im also assuming that when you say everything else works you mean it takes water in heats.. pumps water out ....the problem is usually caused by a broken drive belt.....or worn brushes in the main drive motor....loose wiring connection to main motor....TOC blown in main motor
soloution replace broken drive belt......check brushes in main motor and relpace if badly worn......if the latter items are ok...relace or substitute main motor
regards Sir Galahad
Aug 12, 2009 | Washing Machines
Canon A95 stopped working with lens open
ur lens belt is broken relace it or write to me
Jun 17, 2009 | Canon PowerShot A95 Digital Camera
Proview PL926WBi 19" LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
