First, see the Sears parts site for your washer: It has diagrams of all the major components along with parts, numbers and Sears prices.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24982300&pathTaken=partSearch
Next, see the following for how to release the console and pull the cabinet if necessary,
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=cd522bc789a1c2dfd6239645284bf1ff
Finally, see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has a complete description of how the washer works along with troubleshooting sections.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You don't say what the problem is but most problems with these washers can be traced to either:
A faulty LID SWITCH (the Whirlpool manual has a description of how to bypass the switch to test it)
A faulty Motor coupler
Worn clutch,
or if it simply won't spin and the Lid Switch tests ok, a broken Neutral Drain Assembly.
In
your refrigerators case I believe the Click Here=> 10674902401 Kenmore Refrigerator Parts in that photo you may need to click to enlarge
depending on what type computer you use. Item number 4 is=> 2304146 Control Board this is a defrost control board found behind the
controls just above the top shelf inside your fresh food section and behind the
controls. Many times you may find burn marks that indicate that the board is
defective. Always disconnect power to refrigerator before working with
electrical parts. This is the most likely cause for your refrigerator not
defrosting but only the first thing of three parts to examine. Click here=> Here
you will see item Whirlpool Bi Metal and Defrost Components
Photo behind the rear panel of your freezer rear
panel. The defrost Thermostat is=> 4387503 Defrost
Thermostat and=> 2315531 Defrost Heater Assembly To make things simple begin by looking over
the Defrost Control Board first. Ask me questions and I will help you should you
have any questions, Thanks, Sea Breeze
