Question about Freezers
Black & Decker BF53 Chest Freezer wont freezer after moving to another state. It worked fine and now its just freezing to a frost is all. I'm scared my food is going to spoil. Bought it second hand and ive seen it work.
  • 382 Answers
Dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Posted on Jul 12, 2010
Black and decker chest freezer on frost in the upper half of the freezer, the other half going down to the bottom is just cold with no frost and also the top of the inner part of the door is making ice.
You may have a leak of refrigerant, you may have a warm air leak when the lid is closed, or you may just need to defrost it manually. use heat ONLY, do NOT poke at the ice or frost with anything
Oct 10, 2010 | Freezers
My Freezer temp drops to 11c, I have to keep defrosting & then it`s fine for a couple of months
as its a chest freezer you have no auto defrost,so you must do it your self.make sure all food is wrapped/heat sealed bags.to stop moisture/frost from building up.use a freezer thermometer to set at
-18C and do not over fill,if you live in a high humidity area then every other month is about right.DO NOT DEFROST WITH STEAM OR HOT AIR.USE CAR DE ICER .then dry thoroughly.
Aug 21, 2010 | Miele 10.2 cu. ft. / 289 liter Chest...
Freezer doesn't freeze anymore. Runs like a
On a chest freezer , the coils are located inside the walls of the freezer . The heat normally felt on the outside is the condensor coils inside the wall. The coldness felt on the inside is from the evaporator coils also inside the freezer wall .If the inside of the freezer has over 1/2 inch of frost , then defrosting may work . If NO frost on the inside , possible leak in the coils which are not accessable . Only solution is to replace the freezer . Anyone can buy refrigerant 134a which is what your freezer uses .
Jul 15, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Freezers Logo
796 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
