Question about Hampton Bay Dryers
I own the Glacier model 659907 3 speed fan. i am looking for the 5 wire capacitor (2grey wires, 1 purple, 1 brown and 1 red wire) so that the switch can be fixed. Do you still carry this product and if so, How can I obtain it from you?
  • sol3554711 Jul 09, 2010
    thank you for thelink; they did not however have the specific 5 wire capacitor that i need with the grey, purple, brown and red. i have a older electric ceiling fan that requires that capacitor. Do you know of any other websites that would have these capacitors? Thank you
  • 532 Answers
Go to the site and you will get the part of the speed fan you are looking for.
CeilingFanParts.com - Switchco Products - Pull Chain Switches (http://www.ceilingfanparts.com/images/pullchainsw.htm).
Or
Get the correct switch from the fan manufacturer and save yourself the headache.
Thanks for contacting Fixya.
Posted on Jul 09, 2010
  • Rahman Rufai Jul 10, 2010
    Please, visit the sites below
    www.eceilingfans.com/
    www.faninfo.com/
    Thanks.
Hook up 5-wire fan capacitor
U hook it up the same way the old one was hooked up. Did you take notes or pictures of the prior cap connections?
And without a model number how do you expect anyone to really be of assistance? Huh?
Aug 29, 2016 | Hampton Bay Dryers
Ceiling fan reconnection.
Should have four wires going into switch if it's a three speed. What make/model of fan do you have. If you bought a new speed switch off a rack somewhere most likely you have the wrong switch. Just because it looks the same on the outside (switch) doesn't mean it's the same on the inside.
Aug 11, 2014 | Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
How do I wire a new condensor fan motor to the new capacitor? The old capacitor is longer and it has 3 terminals. the new capacitor is much smaller and oval. It has 2 terminals. the fan motor has 3 wires,...
Before attempting any of these recommendations, First disconnect all the power sources and check your wiring diagrams on the motor and condensing unit.
On the old capacitor if you look on the top near each of the three terminals. Are they marked, fan - C - herm? If they are that is a dual capacitor and that needs to stay because that is also your compressor capacitor.
The Red wire from the conductor is Run and it's connected to C on the old capacitor.
Follow the Yellow wire and see if it goes to the S or start terminal on the compressor, if it does then that is the Start wire for your compressor and it connects to herm on the capacitor.
For the fan motor a lot of times the wiring connections are printed on the motor label.
Check the label, Purple should be run and connect to C on the old capacitor.
Black should be Common and it connects to the opposite side of the contactor as the Red wire. If the Red wire connects to T1 then the Black wire connects to T2.
The Brown wire shoud be the start wire on the fan motor and it connects to the Fan terminal on the old capacitor.
Now if you want to use the new fan capacitor. Take the Purple wire from the motor and look for any marks (red paint or a dash) on or beside the terminals on the new capacitor. If there is an identifying mark then connect the Purple wire to that terminal, if no marks you can connect it to either terminal. Then you need a jumper wire from C on the old capacitor to the purple side of the new capacitor. Then take the brown wire and connect it to opposite terminal of the new capacitor.
Apr 05, 2010 | Heating & Cooling
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Dryers Logo
37 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
