Question about HP Mini 1000 Netbook
Hi i have asus netbook and i think it got hot and shutoff. After cooling i powered back on and there is nothing just the wallpaper...is everything gone?
    President:
  • 2,571 Answers
If you are booting up and getting to the wallpaper, then you probably ok.
try booting into safe mode, usually the f8 key on boot up, and restoring the pc to an earlier state with system restore
Posted on Jul 09, 2010
My Cooker is coming up with a E3 What do this means or how to fix it?
Error Code Error Solution
F0 An internal error was detected. Disconnect power. Wait 5 seconds before reconnecting power. If the symbol appears again, call for service.
F2 The surface cooking area is too hot and has turned off. Remove the pans from the surface cooking area. "F2" will disappear when the surface cooking area has cooled. If you turn the surface cooking area back on and "F2" reappears, the cooktop is still too hot. Turn off the surface cooking area and allow it to cool.
F4 The pot or pan is too close to the control panel. Make sure the pot or pan is centered on the surface cooking area and nothing hot is on the touch control panel. Wait 5 minutes for the control panel to clear. If "F4" appears after turning the surface cooking area back on, call for service.
F8 The surface cooking area has been in operation too long. The surface cooking area automatic shutoff was activated. Turn off the surface cooking area.
C1 The power voltage is too low. Turn off the cooktop. Wait 5 seconds, then turn it back on. If this continues, contact a qualified electrician.
C2/C3 The cooking surface area has overheated. The surface cooking area automatic shutoff was activated. Wait 5 minutes for it to cool, and then turn it back on.
Jan 26, 2017 | Washing Machines
CANT CHANGE THE WALLPAPER
Hi Friend,
In case if you are using netbook, mostly netbooks comes with the starter editions of the OS like "Windows 8 Starter" or "Windows 7 Starter", these Starter editions does not have the option/capability to change the Wallpaper.
So, if you are using netbook with Windows Starter edition, I am afraid you will not be able to change the wallpaper.
Thank you.
Oct 18, 2013 | Acer eMachines 350-2074 Netbook
Hit power surge
it may be due to the damage of power source...i think so...replace your battery..so that it can work...all the best
Sep 12, 2013 | ASUS Computers & Internet
Asus Eee new just wont turn on and it smells like burned plastic at one side
New Gloria?
Take it right back to the store you got it from.
They do not exist anymore?
Then send to Asus. They need to either fix it for FREE, (And pay shipping back to you), or replace the netbook.
Store doesn't want to honor repair, or Asus?
LET ME KNOW
Post back in a Comment.
(Sorry, but I think of Asus, as I think of.......well............NOTHING.
They do not post Service Manuals for their laptops, and this is a strike against the consumer.
Wouldn't have one because of that, if you gave it to me.
Toshiba either. Jus sayin' )
Regards,
joecoolvette
Mar 13, 2013 | ASUS 8.9" Eee 8GB PC Netbook Computer with...
Asus eee pc r101 burnt out
From the description the processor ic has overheated probably due to the cooling fan failing, this a serious motherboard failure and unless you have extended warranty, you are further ahead replacing the netbook.
Mar 22, 2012 | Computers & Internet
Hi i have Acer Apire one happy netbook and unable to set wallpaper
If you can not set any wallpaper try to created a new user. That will probably isolate the issue with wallpaper.
Oct 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I have an Asus eeepc 1001 ha that won't power on. I disconnected it from the adapter, carried it to another room, pressed power on and busied myself with something else while it powered up. (So...
if nothing happens at all i would think the motherboard has died, if it has then there is nothing that can be done about it unless you take it to a computer repair shop and have see how much it will cost to get it repaired.
or
Leave it for a few minutes making sure the battery is out and the charger is out, then wait, plug everything back in and see if it turns on if it doesnt could be the charger is broke instead of the motherboard. try and use a different charger to be sure. Kronoguy
Aug 13, 2011 | ASUS Eee PC 1000HE Netbook
I HAVE A NETBOOK . EEEPC NETBOOK.........EVERYTHING WAS WORKING FINE YESTERDAY MORNING........... THEN I PUT IT ON LATER IN THE DAY. IT WILL NOT GO ON .ALL LIGHTS ARE ON BUT THE SCREEN IS BLACK AND...
it can be problem with your output device but now don't worry because still you have chance to correct it ; ).
First DON'T WORRY BE CLAIM..
Plug out and plug in the battery,...DOES IT WORKS..
IF no, then check your output device by plugin monitor on the port.. again if doen't happen anything then... you have to go to near service center and have a check....
HOPE IT WORKS,,,ALL THE BEST.. ; )
Oct 09, 2010 | Asus Eee 701Sd Notebook
How to change wallpaper on eee pc 1005ha model netbook
go to start thenconrol panel then double click dispay then select the desktop tab all wall papers are there.
hope this helps
Apr 29, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
1. Right click on the empty area of the desktop and choose personalize.
2. Click on Desktop background.
3. Choose the wall papers which you want.
Mar 07, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
HP Mini 1000 Netbook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
