Question about Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset
I have a plantronics voyager 500a that was moved from someone else's phone. It is connected to a cisco 7961 voip phone. The cords are connected the same way as others, but I don't hear anything from the headset. Is there another setting I need to change somewhere?
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
The attached link for the Plantronics 500A/510S should walk you
through the set-up process. Make sure the configuration dial is
correct (usually on #1).
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Posted on Nov 11, 2011
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Phone lifter not working. light on top of base not lit up
Try re-pairing the headset to the Plantronics 500A base unit, it sounds like the headset may have lost connection with the base. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Jul 06, 2011 | Plantronics Voyager 500A Deskphone Adapter...
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Headset not working. red light on base is flashing and yellow light is static; no blue light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Feb 09, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have half a dozen plantronics voyager 500a units, with HL10 headset lifters and 510 bluetooth headsets that do not work. All of these came from the Voyager 510s packs some time ago (with a different...
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
Jan 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
500a will not pair with cell phone. my phone will pair with another bluetooth device so my phone is not the problem. I just got this 500a --- is there any special thing I need to do to pair it with my...
The Voyager 510 headset that's used with the 500a is compatible with most mobile phones. The link below has information that can be of benefit to you, especially page 5 (powering the headset on / off to reset) and page 6 (pairing).
Dec 23, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Switched from Cisco phone to Avaya phone. Do i
Do you have the cord into the headset port on your phone?
Sep 24, 2009 | Plantronics Voyager 500A Deskphone Adapter...
Detecting calls onm Cisco 7961
If the CS70 has a lifter attached to the cisco phone then it should be able to detect an incoming call by beeping in your ear.  If there is no lifter, it won't beep in your ear, but you will still be able to answer.
Apr 26, 2009 | Lands Phones
Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset Logo
377 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
