Question about Pegasus Technologies Pegasus Kitchen Sink Basket Strainer with Flange 89311
Both of the Pegasus baskets in my sink have come apart. I put them back together and they come apart again. I would like to purchase new baskets, but can only find the entire drain assembly, which I do not need. How do I purchase just baskets?
    Novelist:
  • 145 Answers
I know what you mean I had similar problems with my sink strainers, unfortunately is you want to get a good working basket you have to buy the whole drain assembly. You can get some cheap ones at a home store but they will only break again and probably won't match up. What I recommend is swapping out your drains with a drain brand that won't break again like Kohler, Moen, or Elkay. All you need to install a new drain is the new drains, a drain nut removal tool and some plumbers putty. Take the old drain out clean around the whole and install the new one with a ring of plumbers putty around the hole.
Posted on Jul 11, 2010
I have a pegasus sink and I'm having a hard time getting the drain not to leak. The base of sink if thicker in the front than the back so when we tighten the drain it will only tighten so much in the back...
You need to take it off copletly and clean it then take 100% clear silicon put it down on the sink base and on th e bottem lipe of the basket strainer tighten down till silicon sqeezes out top of sink wipe with paper towel and wate 24 hours befor use.
Jan 21, 2011 | Pegasus Technologies Pegasus Kitchen Sink...
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
There is a rubber washer between disposal and sink basket
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
While using our garbage disposal this afternoon, it went from grinding to humming. The blades do move freely, but the plate is very loose and tips. Is it possible to tighten the plate?
There is no way to tighten plate that I know of.
Maybe a clever welder could stick it back together, but the problem implies something underneath is rusted out or broken. The main thing is the cutter plate, and if disposal wobbles, it will loosen drain pipes under sink and cause dripping.
I wrote some tips for installing new disposal, and include them here since disposal will be replaced at some point.
That way we didn't have to change out sink basket.
How to replace disposal:
Make sure there's enough putty that it squeezes up all around sink basket.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Add a comment
Dec 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Pegasus sink. The sink baskets that came with the sink have both pulled apart. Is there a replacement sink stopper and basket that fits this 3" whole without changing the whole unit? I have had a...
Sure, have you gone to there webb site? And even if not the sink basket assm. are not to bad to replace. You can find them at Home Depot etc. Look in your local area phone book for a plumbing supply store. These stores have it all and may be able to help you with name brand ?'s.
May 09, 2010 | Pegasus Technologies Pegasus Kitchen Sink...
I am on my 3rd Pegasus sink strainer (bail-lock basket)in 2 years. The pull handles come off. Is there any way to stop this from happening? Is there any way to contact the manufacturer directly?
Pegasis is a cheap brand of strainer.
I would get a better quality strainer...
ProFlo, moen, franke, Blanco, and even kohler
you might pay a few dollars more, but they will last much longer
Dec 07, 2009 | Pegasus Technologies Pegasus Kitchen Sink...
How do I contact Pegasus to obtain missing parts?
Pegasus is Home Depot own brand of bath room fixture. The contact number should be on the installation instruction or the warranty sheet.
you shold contact Home Depot if you cna't find the contact number.
Mar 28, 2009 | Pegasus Technologies Pegasus Pegasus...
What to use plumbers putty or silicone on strainer basket rims installed on granite sinks
you always use plumbers putty on the strainer baskets. you can never use to much just remove the access when tightened. If you use silicone you will have leaks withen a year.
Mar 24, 2009 | Pegasus Technologies Pegasus 25 In. Black...
Pegasus Technologies Pegasus Kitchen Sink Basket Strainer with Flange 89311 Logo
310 people viewed this question
Top Pegasus Technologies Plumbing Experts
Don Numinen
Don Numinen
jdthefixer
Andrew Bugbee
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
