Question about Siemens WFXD8400UC Front Load Washer
Unable to start the machine
Everytime I try to start, machine makes 3 clicking sounds and stops. Seems like machine is trying to lock the door but it is not locking itself.
  • Siemens Expert
  • 414 Answers
Sounds like a few assumption, sounds like it needs a new door interlock as this model has a magnetic lock and the clicking means it's not engaging. However, worst case scenario is that the module is faulty too.
Posted on Jul 09, 2010
I get the F-21 error code and the washing machine stops mid cycle.
Unplug the plug for 15 seconds plug it back in and try again
Jan 27, 2015 | Washing Machines
I have a high efficiency washer and I am unable to start my washer because the lid lock keeps flashing and will not lock. What do I do. This wager is not a year old.
Check the door catch see if there is anything stopping closure.if that is okay try resetting the machine.most reset by switching of from the wall socket.then hold the start button in for at least five seconds whilst switching on from the power point.it sounds like the child lock is trying to activate.read the manual to see if you can set this to default.
Jan 24, 2015 | Washing Machines
When the machine is switched on there is a clicking sound from the door and the machine won't start. Opening and closing the door and giving it a thump, works after 2 or 3 attempts. Is the problem
Had a similar problem with our Kenmore front load washer, our grandson was caught leaning on door while it was open and it bent the hinge slightly, this misalignment resulted in the latch mechanism trying to lock the door shut( needed as a safety measure to prevent leakage) but it was unable to do so. Had limited luck with lifting the door while shutting it and holding it closed while pushing the start button,but eventually had to replace hinge. Parts man at service desk also advised not to hang wet heavy items on door (don't know why anyone would want to) as the same thing could happen,also don't try slamming door as that could result in costly latch replacement. Hope this was of some help
Feb 24, 2013 | AEG Lavamat 74640 Front Load Washer
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
Nov 26, 2009 | Maytag Washing Machines
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Siemens WFXD8400UC Front Load Washer Logo
258 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
