I have plugged the USB lead into the pc processor for a recently purchased 160 GB portable hard drive but I don't know where to access it to save files to it. When I look in 'my computer' it isn't there. Should it be?
  • 655 Answers
Yaa, it should be in my computer.
  • Check out your portable HDD manual, How to use?
  • Check out if there is any power switch on your portable HDD. Some of external HDD have a switch.
  • If there is any one it must be in on position to use.
If any problem, Just Ask me...
Thanks
Iqbal
Posted on Apr 19, 2008
The USB plug has loosened itself inside the hardrive how do I fix it?
Look up Verbatim in the phone book. Find their phone number. Speak to customer service and they will repair/replace your unit free of charge, even if you don't have proof of purchase. I know, I just got my unit back, all fixed!
Mar 23, 2014 | Verbatim 160GB USB FireLite: The "drive...
500gb toshiba automatic back up portabledrive is not regonized or cant see it
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Oct 23, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
My mother has a Acer laptop only two years old and it crashed when we turn it on it has f2 which is the setup meanu but then the boot manager option doesnt come up after that the screen is black but the...
You can save you personal stuff but you need to remove the hard drive and place it in to a portable hard drive case which plugs in to the usb port on another computer. Then you can transfer you stuff to the other computer and save it on to something else. Then get the laptop sorted out.
Like this:Case
Have a look on the internet if possible to see what a laptop hard drive looks like first so you know what you are looking at in the laptop.
I don't know much about you particular model but usually the hard drive is easy to remove if you have a small screwdriver.
There should be a small panel on the bottom with 1 or 2 screws in it.
The hard drive is in there and may be held in place with additional screws. If so remove them and the drive should slide one way and then lift out. If it's fitted to a small metal cradle remove it or it wont fit in to the portable drive case.
Then just place it in to the portable case and plug in to other pc and access you stuff.
Sometimes there are several panels for things like the memory, the wireless card, the hard drive, sometimes it's one large panel that covers everything.
Don't be scared to have a go, just take you time and a bit of care.
Hope this helps.
Jan 26, 2012 | Acer AS55525898 156Inch Laptop
I plug in my Passport and nothing happens. What do I do now?
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
Nov 11, 2011 | Western Digital WD Passport 250GB Portable...
The usb connecter on my 500gb portable hard drive has snapped off the board. Can this be repaired or is there another way to recover my data that was stored on the hard drive?
unless you can access your 500gb portable hard drive you wont be able to recover any data you have on it
is the connector on the hard drive or the motherboard
if you have more than one usb out put you might be able to connect your portable hard drive
if you have any spare sockets on your motherboard
or you could get usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
if you need more help with this or if i have misunderstood the problem post a reply
hope this helps
Sep 28, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
MY EXTERNAL HARD DRIVE KEEPS SUTTING OFF. WHY IS
Check your powersaving settings in windows. Most external devices will be automatically set to conserve power when not in use. An external hard drive is considered not in use when you are not actively accessing data on that drive.
Oct 12, 2009 | Toshiba 120GB USB 2.0 Portable External...
Info Lost/Portable not recoginize
Assuming you've already tried using it on another PC or Mac (as appropriate) with any needed software installed, and that didn't work, your next DIY step is to remove it from the container.
If you can remove it (most drive makers do not publish the instructions to disassemble their equipment), you can hook the drive up inside most PC (not laptop) cases directly (if they have the required IDE or SATA connection), or take it to your local PC store for a quick test.
As a last resort, you can sent it to a "disk or drive recovery" company to get some or all of your data back if it hasn't been lost to a surface defect on the disk. This is usually a fairly expensive option.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
My computer has stopped recognizing the 160 GB portable hard drive (plug and pray)
better plug it to another pc and observe if it would be recognized by the pc. well, sometimes, portable hard drives takes time to be detected by PC specially when it comes to age, better observe it for about 3-5 mins, and if its not detected, try to touch the usb cord of your portable hard drive connecting to your pc and make some adjustments to it.
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
