I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
  • 484 Answers
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Posted on Jul 09, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
E4 Error in Hunday Split Ac
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
where are you located , like if your residing in noida UP then u would face the issue due to polluted air , and the dirty and harzadeous gasses comming out from back water river, next time when technicians come , kindly ask them for proper flushing and testing it by nitrogen pressure. there can be a minute leakgae.
Mar 19, 2010 | Heating & Cooling
SPLIT AC
PROBLEM WITH THE INSIDE FAN MOTOR
Sep 27, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
1,817 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
