Question about KitchenAid KTRP21KL Top Freezer Refrigerator
The refrigerator door requires a firm push to shut; opening/shutting freezer door causes the refrigerator door to pop open. What's wrong? And, how much should I expect to have it repaired? (I'm wondering if it'd be cheaper to buy a new refrigerator.) I've checked the seal for obstructions. I've checked to make sure nothing in the refrigerator is obstructing the door. I've rearranged food on the door. The hinge looks okay. The problem started suddenly after a I cleaned up a large bottle of tea that had been spilled inside.
    Top Expert:
  • KitchenAid Master
  • 12,962 Answers
Checkout the hinges for either having corrosion and/or being out of alignment.
Posted on Apr 29, 2017
2 Suggested Answers
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
Freezer door pops open about 1/8" when you shut refrig door
this is very normal this means that you have an extremly good seal .. causing air to push threw duct work when closing door .... try changing the levelnes of refrigerator so when door does pop open it falls back closed meaning tilt fridge front higher than back of fridge
Feb 01, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
The temp of freezer rises after you open and close the door
all the cold air is dropping to the floor of the kitchen and being replaced by the warm/wet air in the room(take your shoes and socks off to get the benifit,nice)
Jul 20, 2010 | GE PDS22MIS Bottom Freezer Refrigerator
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator door is not shutting right
You need to replaced the door cam assembly on the bottom of the refrigerator side. It is probably cracked and hanging up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer door won't stay shut
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Fridge door does not
you can tilt it back a little rule of thumb that i use is to tilt them back open the door as normal let it go and see if it shuts its self if that doesnt work let me know we will try something else
Feb 10, 2008 | Refrigerators
KitchenAid KTRP21KL Top Freezer Refrigerator Logo
54 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
