Question about E-Machines T3120 PC Desktop
The moniter looks like the horizontal hold has gone out the bottom half of the screen is black only the top half shows or there is just a bright horizontal line in the middle of the screen is it cheaper to repair or should I just buy a new one?
  • 570 Answers
It is good to buy a new one because if you get it repaired even if you are not satisfied with the result what then? So my advice is to buy a new one and you will have a satisfaction of having a new one.
Thanks for asking a advice from me
Please rate me if this solution works for you
Thanks......Have a great time.
Posted on Jul 11, 2010
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Change I-phone screen from vertical to horizontal
You can change your screen from vertical to horizontal by the way you hold it. If you have the vertical/horizontal turned off you just unlock your phone and slide up with your finger from the bottom to the top and the menu with brightness, sound, airplane mode, wireless,etc., will come up. Click on the last bottom in the first row that looks like a lock with a circle around it and make sure it says that its off (which will be black instead of white).
Oct 13, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
E-Machines T3120 PC Desktop Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
