I have a Simplicity 12000 BTU air conditioner and it is leaking water from the right corner on the bottom of the unit. The water does not travel to the storage tank.
  • 518 Answers
A pipe is a=puntured, b=the securing clamp is loose and needs tigning,,c=the matrix element has cracked,needs changing,remove cover to see where the leak is
Posted on Jul 09, 2010
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
Jun 20, 2012 | GE 12000 Btu Room Air Conditioner EnerStar...
Water
This ac unit will have to be taken apart and clean out the drain holes in the bottom of the case.Use a water hose to clean and wash it out,also remove any large objects by hand,of course you will have to remove the unit from the window to do this.
Apr 16, 2012 | DeLonghi PAC C120 12000 BTU Portable Air...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
HOW MANY TONS IS THIS UNIT WEATHER KING 10AJA4801AH?
It's a 48,000 BTU AC - so 48,000 divided by 12000 = 4 tons
Note: 12000 BTU = 1 ton of air conditioning
Jun 10, 2011 | Weather King 10AJA4801AH Air Conditioner
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
Jun 06, 2011 | Samsung AW0603B Air Conditioner
Fan is working on inside unit and also on compresser unit outside, but compresser does not produce cold air. The air conditioner is an Airforce easy fix 12000 btu pack.
you are most likly short or out of refrigerent which mean you have a leak somewhere find a refirgeration mechanic.. if need be fill it with nitro to find the leak
Jun 29, 2009 | Heating & Cooling
Heating & Cooling Logo
405 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
