Question about Garden
My mower will not move I replaced drive belt and it moves.
    Guru:
  • 440 Answers
So what is the problem??
Posted on Jul 09, 2010
Murrym19546 riding mower want move why?
I would believe the mower is ran off a belt and the belt has stretched to the point and needs replacement. Raise the mower up and look under it and see if the drive belt is sloppy or loose.
May 26, 2017 | Cars & Trucks
Install new drive belts and mower still wont move forward or reverse.
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
Jun 27, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
The mower with not move! I put it in forward push the gas paddle and it will not move. It just wont move, it has a brake paddle and a gas paddle and brake. All yard machines basicly have the same setup in...
Inspect the drive belt,if it is broken.Under the hood is a list of parts and part numbers.Find the drive belt on there and get a replacement.The package the belt comes in has the diagram for installation on the back.Would not be a bad idea to go a head and change the deck belt if it is ore than 2 years old,while you are under there.
May 12, 2011 | Yard Machines 155 Torque Briggs Stratton...
1180 cub cadet replaced both drive belts length of belts is correct,mower still moves if foot peddle is not engaged.per manual set the adjustment of the drive pullys and the problem is still there.I have...
If you did not use the original manufacturer belts it will cause this as lawn mower belts are designed to slip when not under tension (so called graphite Belts) where other belts are designed not to slip even when some tension is lost.
Nov 07, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Apr 03, 2010 | Craftsman Garden
If the belt comes off a riding lawn mower...will it still cut grass
Probably not.
I would expect to find two belts on a riding mower; one to drive the riding lawn mower (lets call this the DRIVER) and one to drive the actual mower part (lets call this the MOWER).
To answer your question one way, if the driver belt is off, it will still cut grass, but you cant move the mower. If the mower belt is off, it will move but not cut the grass.
If your belt is broken, take it to an automotive parts store or garden equipment place for replacement. You might also support a FixYa.com advertiser.
I hope this answers your question. Thanks for posting at FixYa.com and please vote.
thanks
a
Nov 14, 2009 | Garden
My murray 16.5 42' will not go in gear. what to do
If this is an older mower it will most likely have to do with the linkage, it is worn and will create some problems for it to go into any gear. I just had the same problem with mine. If you are able to move the gear shift but the mower is not moving you will need to replace the drive belt. In order to do this you will need to drop the mowing deck to replace the drive belt. If possible you will need another person to assist you in order to speed things up. If not it will take a couple of hours by your self.
First put it in first or second gear and check the tension on the drive belt. If it is loose this will be the tell all sign that the drive belt will need to be replaced before the mower will move. However, most importantly check the adjustment for the tension on the belt. If it is not already adjusted all the way you can adjust it to put more tension on the drive belt allowing it to move again without the hassle of replacing the drive belt. If this does not work do the following.
Check your linkage where it goes to the top of the rearend and see if it is moving at this location. If it is not moving the lever at the top of the rearend you will need to replace the linkage in order for it to work;.
I was lucky with mine. Once, I replaced the drive belt it started working. I had no reverse.
Aug 22, 2009 | Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
