Question about Comdial Executech® II 6600E-PG Corded Phone
How do I get my itcm button to stop blinking?
How do you get the message light to stop blinking and the call S12 to go away?
(ITCM # 3 plus your extension number) to cancel message
(ITCM, HOLD) to retrieve message
May 21, 2014 | Comdial 8324S-PT Corded Phone
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
How do i set the time?
Press mode button till the seconds window blinks. Press Lap/Reset button once to make minutes blink. Cycle through minutes using Start/Stop Button. Press Lap/Reset button once again to make hours blink. Cycle through hours using Start/Stop Button to change the hour
Oct 18, 2010 | Kenneth Cole Digital KC3639 Watch for Men
Comdial 7700s has loud distorted audio on intercom with no control
while paging is going on hit the volume button once it is where you want it hit itcm **7 to save the volime setting
Nov 27, 2009 | Comdial Digitech 7700S-PG Corded Phone
Cant get ITCM light to stop flashing - no ring tone for incoming
If you're really lucky, you only put the system in night mode. From extension 10 press ITCM and #. Days :-)
Carl
Jun 03, 2009 | Comdial Impression 2022S-PT Corded Phone
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Can not turn off fluttering intercom light. tried
You didn't try them all or it would have gone out :-)
IIRC correctly it's Inercom # from the operator extension (10).
If that doesn't work, post back and I'll actually read the manual.
Carl
Feb 27, 2009 | Comdial 8324S-PT Corded Phone
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Comdial Executech
Press ITCM # 1 to turn off Speaker button light
Jan 15, 2008 | Comdial 6600 LCD Display Phone...
Fixing the time and date
I have had a similar problem,
I found this on vertical.com
Try this: ITCM, *, #, 0, *, 01, MM, DD, YY, HH, MM, #, SPKR to end
If that doesn't work try this, some tech gave me this sequence and it worker for us: ITCM, *,#,746,*,01-SET TIME
Nov 09, 2007 | Comdial 8324S-PT Corded Phone
Comdial Executech® II 6600E-PG Corded Phone Logo
53 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
