Question about Smeg 24 in 60 cm Stainless Steel Electric Multifunction Oven - FU65-5
Oven not heating up properly
If this is a thermostat problem can we fix this ourselves or not and how much will it be to fix it
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
How much to have electronic control board replaced on Frigidaire stove? The readings are too dim. Can we fix it ourselves?
Capacitor C3 a 68uf 35v could be faulty. Check this link out if you wish to attempt a repair - http://www.badcaps.net/forum/showthread.php?t=7902
Jun 30, 2014 | Jenn-Air WW27430P Stainless Steel Electric...
Is there still a Model RBE97N thermostat in stock anywhere?
Unless you know for a fact the oven's thermostat is indeed broken burned up charred ect.. you may consider checking out this quick fix first. On these older models the over will not heat if the setting on the clock is turned to the off position. Check out where it says on the face of the clock right hand side of it "After cooking reset to Manual." It's very easy to miss or overlook. If your sure you need a thermostat I've found two in stock at a place online ... www.appliancepartspros.com and also Electrolux-Thermostat-Parts.com has direct replacements for that old Honeywell thermostat your oven uses.
May 27, 2014 | Ovens
Oven not working
Gas stove check gas oven safety value
Mar 17, 2014 | Ariston Technologies Ovens
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
Temperature is unreliable. Temp is not what I select. I have been using a thermometer to gauge it. I put in a new thermostat and the problem has not been fixed. Now temp is usually approx 30 degrees C too...
It may be the part that connects to the thermostat is out of calibration. Some ovens use a capillary and others use a J thermocouple ... without knowing what make and model I can't tell you how to change it
Feb 23, 2011 | Ovens
Burning smells
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.(this is a fire hazard)
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Jun 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
Fixing thermostat on oIder Hotpoint Double Oven
Hello, there is no fixing the thermostat although some of the older thermostats could be calibrated by using a very small flat head screwdriver in the shaft of the thermostat if there is no opening for a tiny screwdriver in the shaft then it cannot be calibrated. If you have to change the thermostat contact your local parts department have the model # handy if the original is not available ask about universal oven control replacement parts. Good Luck
Dec 21, 2008 | Zanussi ZDQ895 Electric Double Oven
Smeg 24 in 60 cm Stainless Steel Electric Multifunction Oven - FU65-5 Logo
337 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
