Question about Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner
I have a SPT model WA-9000E portable air conditioner What is going on when i turn it on to HIGH SPEED COOLING IT ONLY COOLS ON HIGH FOR ABOUT TEN MINUTES AND THEN CLICKS TO A WARM SETTING AND THE AIR IS WARM INSTEAD OF COLD STAYS LIKE THAT FOR SEVERAL HOURS THAN KICKS ON HIGH AGAIN AFTER TURNING IT OFF AND BACK ON AGAIN
2 Suggested Answers
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
Spt Wa-2211s window unit will not power on
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you are having prolonged air conditioning check out Air Conditioning Tamarac for more HVAC Support
Jul 20, 2016 | Heating & Cooling
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
The unit just quit working. The panel lights work, so power is to the unit. If I power off, then on again, the FULL light comes on and then goes off in a couple seconds. No cooling, no fan, NO ICE!
I couldn't find much information about this unit on the net. What I think it might be is that the sensor or control board that responds to the sensor is failing, and, thinking the ice is made, turning off. On this site, in the first review, someone mentioned something being loose inside the unit and just needing tightening, so perhaps that will be a clue:
http://wize.com/reviews-air-conditioners/sunpentown-wa-7500m/page-4
Good luck, hope this helps, and thanks for using FixYa.
Sep 12, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
Spt portable ac unit keeps tripping and will not turn on
Sounds like you have a short in the high voltage wiring. The compressor may be bad.
Mar 10, 2009 | Sunpentown WA-1220E Portable Air...
Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner Logo
291 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
