Question about Samsung SyncMaster 710PM 17 in. LCD Television
How to Disassemble the back cover I need is to eliminate false contact in TV signal input
  • Samsung Master
  • 8,457 Answers
Take out all the philip screws with a Phiilip screw driver in every holes.The back cover should come right out,than do what u must do.
Posted on Jul 09, 2010
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
I have logik l22fedr12 TV and it keeps going into scan mode and I can't stop it or use tv, how can I fix this?
When you say scan mode, is it scanning for input signals? I'd check the buttons on the tv and make sure the input button isn't stuck in the depressed mode as if someone was pressing it. I'd also take out the batteries from the remote to eliminate that device as a possible source to your problem.
Apr 15, 2015 | Televison & Video
My TV showing double image on right side
Hello
There are two different signals comes to the the input of your TV, that is to the antenna terminal of your TV. Try reorient or reposition the antenna. This fault is called Ghost image. Changing the position of the antenna can eliminate this. Try it with different directions, and different positions to eliminate this fault, while watching a tranmission signal. OK.
Apr 30, 2011 | Televison & Video
Clicking in dash sounds like turn signal relay. We think it may be hazard switch malfunction anyone know ?
we have an 03 grand am and took to mechanic. he replaced relay behind dash in center area behind radio. it still made clicking noise and he said it needed a new 250.00 plus turnsignal switch. went to junkyard and got one for 14.00. but it didnt help
we disconnected battery ( hoping that would eliminate chance of air bag going off) took out turn signal switch. placed switch on bench and took it apart with a T-10 torx bit. and cleaned TURN signal contact points with cloth. regreased a little with some of the grease that was in there. (not sure what kind of grease it is) Put back together and it seemed to eliminate clicking noise.
Sep 12, 2009 | 2001 Pontiac Grand Am SE
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Mar 09, 2009 | Insignia 42" Flat-Panel Plasma HDTV
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
My sharp tv model 20H-S60 remote input button is not functioning.
Go to www.remotes.com and they will tell you in most cases how to revive your old remote! or order an orignal (which you may have to do to change the function!) tv remote for your model!
Jan 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Jul 11, 2008 | Televison & Video
Samsung SyncMaster 710PM 17 in. LCD Television Logo
Jerry Greenberg
Jerry Greenberg
