Question about Polaris 800 Twin Sportsman Ride on Toy
Stop working after a couple minutes then starts again. Battery fully charged. When pedal is pushed just clicks in fwd and rev.
    Genius:
  • Polaris Master
  • 1,508 Answers
Known issue, you'll need a motor upgrade kit, might be covered under warranty, let me know if you would like me to check
Posted on May 23, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: short from pedal to battery
I would replace the foot pedal switch like the one here http://www.shopjandl.com/mepu0001.html
if it goes in any speed then it is a problem with the switches in the shifter.
You also want to make sure the wires are secure on the foot switch and the motors because the can come loose when the children are riding them.
I would also contact J&L http://www.shopjandl.com/.
These guys know a lot about these peg perego gators and will make sure they help you.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: Gator stops suddenly and will not go with pedal depressed.
it could be a switch problem, or loose connection. I use the repair help at
http://www.mypegperegoparts.com/ when I need repair advise for these toys.
hope this helps
Posted on Jun 08, 2010
Battery light came on a couple of days ago. Last night it started and as it was going the radio stopped working and the engine was reving as if stuck in 2nd gear. After shutting off the van it would not...
problem on battery light came on, loose belt tension. power is out so all part will not work. and check the battery again, make sure it was fully charge.
Jan 30, 2011 | 2001 Chrysler Town & Country
Ranger on a full charge stops working within 5 minutes. After 3 minutes or so, it runs again. Is the battery fried? Or is it overheating? It is aprox 1 year old. It is being run on flat ground. Please help
If power stops abruptly then theres a chance there coul be a loose connection and needs investigting. If power winds down and stopsthen yes the battery is probley fried.
Jul 16, 2010 | Polaris Ranger RZR Ride on Toy
When I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the...
You didn't specify a brand or type but it sounds like a hydrostatic drive model and if so, it is 1 of 4 likely things
Drive belt from engine to transaxle slipping badly (replace the belt)
FWD-REV pedal linkage faulty
Transaxle is broken or has fluid issues (not user fixable)
by-pass rod (neutral lever/rod) is pulled out a bit. (push it in fully!)
Jul 11, 2010 | Garden
hope this helps
Jun 01, 2010 | Peg Perego John Deere Gator HPX Ride on...
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
When i push the starter button, there is a clicking sound...engine tries to turn over but then stops and only the clicking sound remains. i recently replaced the battery. cranked right up after...
Charge the battery up fully and see if it will start. I am betting that the battery was dead. when you get it started you are going to want to test and see if the motor is charging the battery. Use a volt meter and have the battery charged fully and start the engine. With the charger off the battery take the volt meter and touch the + with the red lead and the - with the black lead. At idel you should have 13.6 volt of higher but no more than 14.2 Now rev the motor up to 3000 rpm and the volt meter should jump up as you rev it. If it does not then the reg/rec is bad or the stator went bad.
Nov 18, 2009 | 2001 Yamaha V Star 1100 Classic
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Ford fiesta 1.3 97 petrol sometimes won't start
change battery ,if it starts with jump leads battery flat or altenator not charging
Nov 17, 2008 | 1998 Ford Escort
Electrics
in fact only turned over once befors starter was clicking away. Pushed it home tried again - nothing. Put battery on charger - charged up in 15 minutes - tried to start - engine turned over couple of times then click click click at starter been out this morning checked all connections and earths - charged battery up - read 13.22v when full charge light came on, tried to start up - turned over several times, getting slowwr then click click. Checked battery reading 12.17v Any suggestions - is it the battery or what else?,The fact that the voltage drops as the revs increase is very odd. However, the dash voltmeter which I assume you are using is often inaccurate. Try an alternative battery, at least to see if it starts. You could use a car battery with jump leads. With a decent battery the charging might improve too.,,,
Nov 10, 2008 | 2002 Moto Guzzi California 1100 EV Special...
Electrics
Polaris 800 Twin Sportsman Ride on Toy Logo
98 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
