Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftman ZTS 7500 INTEK PLUS 42 inch deck twin blades riding mower cuts uneven. Also the left turn handle tends to not work efficiently when trying to turn left.
  • 532 Answers
If the blade does not cut evenly, folllow the step below
The rear tires must be the same diameter i.e. same tread type and the same tire pressure
a. (check it before each mowing).
Level the deck following the instructions in the manual and recheck it occasionally
Make sure the blade(s) are not damaged and kept sharp, rounded blades tear instead of cut.
Make sure the deck and its attachment points are not bent or damaged.
Drive at a slow walking speed with the engine at cutting speed.
Over lap rows in amounts sufficient to lift and cut the tire tracks from the previous pass.
Cut the grass at intervals that ensures you never have cut more than 1/3rd the total length of the grass.
Make sure the underside of the deck is clean.
Use a blade style that matches the type of grass you most often mow.
If the left handle does not work efficiently, power steering fluid for 30 minutes and it will be okay.
Thanks.
Posted on Jul 09, 2010
How o you change the lift assembly on a craftsman ZTS 7500 mower ?
Should be relatively simple. There are 4-5 cotter pins that connect the mowing deck to the bottom of the mower. Pull the pins, push the metal rods out, and remove the deck!
Jun 17, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
253 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
