Question about Frigidaire GLGR331A Gas Dryer
Need to take off front panel to remove accumulated lint below lint filter. I took out as much as I can but there is a lot more. We do clean the filter with each use.
  • Frigidaire Master
  • 8,220 Answers
Use a putty knife to release the top
Need to take off front panel to remove accumulated - 1_13_2012_9_15_36_pm.jpg
Remove the screws holding the front and get it out yer way. Take the back service panel off and release the idler from the belt and lift out drum using the belt to help you.
HOW TO VIDEOS
Posted on Jan 13, 2012
5 Suggested Answers
  • 489 Answers
SOURCE: front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Posted on Apr 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
  • 3 Answers
SOURCE: Bosch Nexxt 500 series gas dryer lint building up inside dryer
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue
Posted on Dec 01, 2009
Why am i am getting lint on my wash, what can i do to prevent this? Spinning causes lots of lint to accumulated in the drum holes.
Clean your filter. Are you talking about your washing machine or dryer? If dryer, clean lint filter after every load. Also you should immediately check to ensure your exhaust hose is not clogged with lint. Also look at the exhaust opening outside your house to see any visible signs of lint. If you have lint that is accumulating in the house it can cause a fire. Check this!!!
Feb 23, 2015 | Washing Machines
How to clean debris below lint filter Frigidaire Gallery GLER341as1
Pull the exhuast vent off the back of the dryer, remove the lint screen and then turn it on for a few, should just blow out the back.
Jan 09, 2013 | Dryers
I have a lot of lint below the lint screen how do I remove
You have to dismantle the dryer to clean completely, Sometimes the lint filter may need to be cleaned half way through a cycle if there is a lot of lint buildup.
Mar 10, 2012 | Whirlpool Dryers
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY IT IS WORKING BECAUSE IT HEAT BUT THE CLOTHES ARE WET
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Oct 13, 2011 | General Electric Dryers
I need to clean the lint filter on my whirlpool duet front loading washing mashine. where is it located and how can I get to it?
Its not really a lint filter ,it catches everything that gets down to the drain pump.You need to remove the lower panel on the front of the unit(three small screws one on each side and one in the center down at the floor) pull out bottom of panel to axcess the drain pump. MAKE sure to unplug before working inside.drain pump will have two hoses running to it ,to clean out the filter (trap) turn the cap facing you to the left to remove some water will drain out have a towel to catch reinstall everying in reverse order .sounds like a lot but is actually very easy after the first time
Aug 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get into the dry compartment below the inside of the drum to clean out any excess lint that accumulates there
some dryer have a botton panel that you can take off are some dry you have to take the front panel off the dryer to clean out the lint depend on the dry model
Apr 24, 2010 | Dryers
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
My front loader isnt rinsing my clothes damp
Check to see if the lint filter is overfilled. If so, simply slide it out and remove accumulated lint. Next, check if the exhaust tube from which hot air is expelled is blocked. Clean it out as best as you can - it's possible that a bunch of lint has accumulated inside.
Aug 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I can't totally clean the lint trap on my PYE2300AYW Maytag dryer. How can I completely remove the lint trap to clean it?
If lint has gotten past the lint trap, you can attempt to use a brush just like the previous poster suggested. If that doesn't work you'll have to disassemble the unit. You only need to lift the top up and remove two screws on each side that connects the front to the side panels. The front should then swivel outward. Be sure to detach the door switch and wire guide from the front panel before completely removing it. You can then lift the front panel up and away. You'll need to clean the opening in the bottom of the front panel and also the entrance to the blower.
Jul 07, 2009 | Maytag Dryers
Is there a filter and how/do I need to clean it?
most washing machines have a lint trap that is easy to find. I don't know this model, but open the lid and find where the recirculating water falls out from a hose or plastic tray above the wash tub. somewhere below this point, in the path of the falling water, is a lint trap. remove it and clean it
May 25, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire GLGR331A Gas Dryer Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
