Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet stops running 5-10 minuts
My cub cadet stops running 5-10 minutes after i start mowing but will run on full choke, appears to be run hot
  • 3 Answers
Check the bowl for dirt or try putting in some stable
Posted on Jul 13, 2010
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
Jun 18, 2016 | Cub Cadet Garden
Cub Cadet HDS-2135 13B-214F100, runs great for 45 - 60 minutes then cuts out, only run on full choke, cannot mow but runs. Cools down works fine again
check the fuel filter and fuel line. it may need to be insulated to protect from heat. running on choke means it is starving for fuel . take the carburetor off and clean it real good. be sure the fuel lines are away from heat source.
Jun 09, 2016 | Cub Cadet Garden
Troubleshooting
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
25 hp kholer engine will not stay running without the choke on
if the fuel is newer than 30 days you need to rebuild the carb if not try fresh fuel first
Aug 11, 2012 | Cub Cadet Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet tank stops running 5-20 minuts after i start mowing but will run on full choke, have taken carb apart and cleaned well , bypassed fuel filter, cleaned air filter, checked plug , changed fuel...
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Apr 28, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,357 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
