Question about DISH Network IR Remote Control
Can't use remote to change dish channels batteries are working fine
    Problem Solver:
  • 17 Answers
Hello my name is Michael Hurst with DISH Network. Sounds like your remote may need to be reprogrammed to the DISH receiver. You can press the Menu button on the receiver and that will get you to the System Info screen. Once you have this screen then press and hold Sat button until all the buttons on top of the remote flash red. Let go of the Sat button and pick a number between 1-15. Once the number is selected then press # and then Record. Watch the remote code number on the System Info screen. If this doesn't work then unplug the reciever from power outlet for 10 seconds and perform the step again.
Posted on Feb 01, 2011
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
Hi,well um my dish remote controller is like disactivated or something because it wont change channels,I don't know if its the remote controller or the batterys or the dish box thingy,please help.
Hi my nameis Mike Houston of DISH Network and I see there is an issue with the remotecontrol not changing channels. The first thing you will need to do is changethe batteries and I will send a link that helps with the steps for readdressingthe remote, if you have any questions or concerns please e-mail me at michael.houston@dishnetwork.com.http://www.dishnetwork.com/SupportSection/remote-control
Aug 01, 2011 | DISH Network 322 DTV Receiver
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
4.0 dish remote will not change channel or even turn satelite on or off? still controls the tv just fine, volume works etc....
Hey there! This is Becki Barned with dish Network customer service. The remote just needs to be reprogrammed! Take that remote to the front of the receiver, and then follow these simple steps! http://www.dishnetwork.com/SupportSection/remote-control Hope this helps!!!!
Dec 16, 2010 | DISH Network IR Remote Control
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Second remote not working correctly.
i put an extende piece of cable on my antena for second set raised it to same hieght as my tv in rear so ya dont see works great now
Mar 01, 2009 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
184 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
