Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
How to reset lamp time on projection tv - Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Press the down volume on your TV and press mute on your remote (same time) you will see the green light flashing
Posted on Jul 31, 2010
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
How do I reset the lamp meter?
Press and hold Volume Down button on tv and Play/Split button on tv remote at same time for 6 or more seconds to reset lamp timer.
You will get lamp timer reset to zero message on tv screen on successful reset process.
Sep 04, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How reset the lamp in panasonic tv PT-50LC-14 ?
While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
TV will show lamp reset message on screen.
Thanks.
May 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Need to reset the lamp time on my PT-52LCX66
To reset lamp timer in Panasonic PT-52LCX66..
Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen.
Thanks.
Sep 02, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
