Question about Akai LCT3201TD 32 in. LCD Television
TV continues to turn off on its on
TV keeps turning off like its overheating or something. Dont know. Will only stay on for a few minutes before turning off.
  • 11,361 Answers
You will have to look for cold solder joints in the power supply board first and check the voltages.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 09, 2010
My Samsung HL-T5075S TV shuts off after being on for awhile and will not turn back on,also if you turn it off you have to wait awhile before turning it back on, I have tried unplugging it for up to one...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Sep 15, 2011 | Samsung Televison & Video
TV comes on, but shuts off after 3 minutes. I must wait at least 5 minutes to get it to turn back on again. TV will ONLY stay on if DVD drawer is OPEN!
dvd is overheating its circuit. Keep the tray open to dry up condensation. then leave TV on standby to keep moisture out.
Dec 07, 2010 | Toshiba MD13N3 13 in. TV/DVD Combo
T.V keeps shutting itself off
it may be due to overheating, ensure proper ventilation, clean the ventilation grill, may be the psu is not functioning properly and being over heated, if the tv starts normally after few mins then its the case of overheating.
Jul 29, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsu WS-55411 RPTV-power going on and off..won't stay on!
It is possible that the Low Voltage power module is defective, however I would first check the High Voltage power supply for bad capacitors (they tend to go bad first). In fact check both boards for bad capacitors (they will look puffy in appearance if they are really defective).
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 14, 2009 | Mitsubishi WS-55411 55" Rear Projection...
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Hi there. i have a Sharp tv (SX68RF8) which seems to turn off (go into stand-by mode) on its own after few minutes...sometimes it stays on longer sometimes it turns off in seconds..i always have to tur it...
Sounds like something is overheating or it is getting noisy power from the mains.
Try leaving it off for a while and point a fan at it, if it turns on and stays on for longer then it is obviously a thermal issue.
Such a problem would need to be addressed by a qualified factory trained repair technician.
May 02, 2008 | Televison & Video
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
The flashibg red light
John, I do not know of a code, but it is a good idea in the design to have several goes at starting a circuit, before completely shutting it down. Oscillators are supposed to self start due to noise generated. Some electronic circuits require a reset pulse to be generated before the start up is allowed. The reset circuit may not be generated if the set is turned on again too soon, so it will stay in standby. This may normally be a few minutes to 30 minutes so it seems something in your set is faulty and could get worse. Try a test run with the back off and clean it out of dust with a long brush to keep it cooler. Make sure little fingers cannot get near it. Look to see if anything is obviously overheating.
Oct 21, 2006 | Thomson 24WK25U 24" TV
Akai LCT3201TD 32 in. LCD Television Logo
135 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
