Not draining says filter is clogged. Where is the filter located?
Down near the pump. Remove front panel and down near the pump you will see a knob the you twist off and thats your filter be careful. Water is probably still in the drum so when you remove that filter peice water will come out. Easiest way of doing it is to tilt the machine back and than remove it. Have a small bucket to catch the water. Remove whats in the filter than replace making sure its tight.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
