Question about Amana ATB2135HR Top Freezer Refrigerator
I was recently given an Amana TH25TW. The
I was recently given an Amana TH25TW. The temperature control doesn't have any numbers on it. How do I know which direction is cooler and which is warmer. I'm guessing the further the gauge is to the left, the cooler it is. Am I correct inassuming this?
    Novelist:
  • 160 Answers
Usually yes thats how it works. Take the fridge side and move it all the way left and see if it clicks off. Wait a few minutes than put it back in the middle. If it clicks off than you are correct so place both knobs near the middle.
Posted on Jul 10, 2010
Model TH25TW
10433512 Center Hinge
12077305 Top Hinge If you still would like me to list each part please tell me after you have priced these parts, Thanks Sea Breeze
Door Hinge and Accessories Photo
TH25TW Part Numbers
TH25TW Part Photo's
Jun 29, 2013 | Refrigerators
I have an old Amana top freezer (model TH25TW). I cant find out how many cubic feet it is; so, that I have an idea of what size that I want to replace it with.How can I find the size?
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Jul 12, 2011 | Amana Refrigerators
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Amana ATB2135HR Top Freezer Refrigerator Logo
113 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
