Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I put my memory card in my camera and it says card write protected how do i fix that
  • 42 Answers
Look on the memory card - is the lock switch in the "Lock" position? If so, unlock it.
Posted on Jul 25, 2010
What if its a new memory card? its not locked and it still says the same thing?
Posted on Jan 08, 2013
  • tarrago96 Jan 08, 2013
    what if its a new memory card? its not locked and it still says the same thing?
3 Suggested Answers
  • 11967 Answers
SOURCE: Canon PowerShot SD790 IS Digital Camera
Sounds like two things are happening here. You may be putting the card in improperly...check the manual to see if the card should be face up or face down. Also, be sure the slide switch on the side of the card is in the unlocked position.
Posted on May 14, 2010
bunnydawg
  • 5158 Answers
SOURCE: when i put my memory card in camera it say memory
format the memory card in the camera. if that doesn't work... format it on your computer but make sure it's formatted to fat and not ntfs.
Posted on Jan 09, 2011
Every Time i Put In My Memorie Chip It Tells Me protected Card It also don't let me erase or go to the menu, how can i fix it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 29, 2010 | Fuji Finepix Z20fd Digital Camera
My memory card is saying Write protection every time i put it in my camera. What do i do to fix it? it is not on lock mode because i flipped the switch on it.
The actual switch that detects whether the memory card is in write protect or not inside the camera is probably stuck in the "write protect" position. With a flashlight, inspect the switch in the memory card compartment.
Nov 06, 2010 | Cameras
I put a sandisk pro duo memory card into my camera but it says it cannot format because the memory stick is protected; how do i fix this problem so i can use it with my camera?
There is a small latch on the left side of the memory disk jacket where you will find Lock written, If you pull it to the unlock position then the write protection on the card will be removed. Please do that and use the card.
Dec 06, 2009 | SanDisk 2GB microSD Memory Card
Camera or memory card "CARD FULL" error
Check to see if in your settings you are putting the pictures onto the memory card or the cameras internal memory. If there is no internal memory, then I guess that's no help. Also check to see if the card is write protected (a little switch on the side of it).
Apr 13, 2009 | Fuji FinePix Z2 Digital Camera
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
The Camera is saying "protected Card" and wont let me take any pictures and wont let me un protect it how do i fix it?
Just solved by looking at the memory card itself......there's a switch on the actually memory card......click it & then put it back in the camera!!!!
Aug 22, 2008 | Cameras
How to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Memory card has a slider switch which prevents write access. Move switch to other position.
May 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
i am having lg 6600 it is showing protected how to un proected it?
Nov 18, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
Camera can not find lens and memory card, how can i fix it
Hello, I suggest you to download your photos in your PC first. Then you format the card by PC. Now insert the card in your camera and just format again, i think prolem will be fixed. good luck...
Jul 24, 2006 | Olympus Camedia C-3030 Zoom Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
408 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
