I HAVE THE ION USB 2.0 EXTERNAL HARDDRIVE I CANNOT GET IT TO INSTALL ON XP BECAUSE I LOST THE PRODUCT DISC THAT CAME IN THE PACKAGE
  • 76 Answers
Search up on Google for your device's driver software.
Posted on Jul 09, 2010
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
My Lacie external hard drive used to turn on when the computer using XP was turned on. It has stopped doing this. Any suggestions to solve this?
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 12, 2011 | LaCie Computers & Internet
I have to reload all drives etc but harddrive dont work i have bought a external harddrive but unable to get this to work as pc is not recognising it how do i get my recovery disc to work
remove harddrive from computer make it external by casing it then keep for scanning, if any virus found then remove it.place the **** to pc then install window XP again, then it will detect
Jun 18, 2009 | Computers & Internet
Device driver problem in Windows XP using a USB 2.0 device on a laptop with USB 1.1 controllers
Disable the USB 1.1 on-board option from the motherboard and install a 2 or 4 port USB 2.0 PCI/ISA card.
These cards are quite cheap these days and will do the trick rather than replacing the more expensive back up external hard drive ESATA/USB 2.0 hard drive.
Apr 14, 2009 | Computers & Internet
How to remove the internal hard drive
enter in bios and disable ide or sata on which your harddrive detectd.
then simply install win xp in external usb harddrive.
Jan 04, 2009 | Toshiba Tecra M7 Tablet PC
Toshiba satellite a205-s5831 Received kernel data error. Hard drive has clicking noises. Programs ran slow. Chkdsk running now for over 15 hours and only on 11%..preplacing bad clusters.
When a harddrive starts clicking it's on it's way out.
Buy a new harddrive and at the same time get a USB to laptop harddrive adapter. You can reinstall XP with the recovery disks that came with your machine ans then slave your old drive to your laptop and recover your personal files.
If you really want to get technicalbuy an Apricorn housing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817155602
And two new harddrives, fit one new harddrive to the Apricorn housing and try to install the EZgig cloning software to your dying Windows. You can clone your existing Windows install to the new harddrive in the Apricorn housing and then move that drive to your laptop, the second new harddrive can then be fitted to the Apricorn housing and used as an external harddrive.
EZgig comes with the Apricorn housing and you could even go so far as to create a clone of your Windows install to the new external harddrive. The Apricorn housings are excellent, they are small enough to carry in your laptop case and all they need for power is a USB port.
Sep 01, 2008 | Toshiba Computers & Internet
Asus operating syatem
Ok your gonna need a couple of things to put XP on the Linux Eee PC.
A usb 2.0 CD or DVD
The Offical windows XP service pack 2 disc from Microsoft
A usb flash disk larger than 1 gig or an external harddrive
ASUS PC Eee support CD from original package.
If you have those things the ASUS Eee XP installation instruction manual can be downloaded here
May 01, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
