I have preset to record via the guide method and clicked on whole series by mistake. Now want to cancel this and cannot find a way with the manual supplied with our machine. This was a download since purchasing our humax recorder. Please advise.
    Sergeant:
    Champion:
  • 319 Answers
If unit has a memory reset, use it. Or unplug from power for 24 hours. Then re-program
Posted on Apr 19, 2008
How do I cancel a series of recorded future events
Find the next event to be recorded in the Guide, press the record button and it will give you the option to cancel a single recording or the whole series.
Jan 02, 2016 | Humax PVR9300T HD DVR
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
I CLEANED THOSE 2 ABSORBERS BUT THE ERROR E 27 IS STILL THERE,SO I HAD TO GO BUY ANOTHER PRINTER,I CAN'T PLAY AROUND WITH THIS ONE ANYMORE,SO I'M ASKING COULD THE MP150 BE FIXED OR NOT, OR IS IT SCRAP!!
Method One: Using Mptool Software to reset Canon MP Printer
  1. Turn of printer then run mptool software this software automatically detect the printer.
  2. Click reset main and reset platen button in the waste ink counter section.
  3. If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
Method Two: Reset manual Canon Pixma MP Printers
  1. Turn off the Printers.
  2. Press and Hold the button Resume/Cancel then press POWER button.
  3. Release the Resume/Cancel button while keeping POWER button on press.
  4. Press Resume/Cancel 2 times and then release all the buttons.
  5. When the indicator recorded GREEN - click Resume/Cancel 4 times!
  6. Turn off and On the Canon Pixma MP Printers. And your done.
Warning: Getting rid of the error message won't change that you might end up with ink leaking out of the printer if you don't either replace or clean the ink wastepad.
Mar 08, 2015 | Office Equipment & Supplies
Enter code
to what, can i buy a noun for $1, says vanna white?
buzzzz no spin again..... LOL
no year car, wow.
but there are 2 codes, one for NAV and one for RADIO
and the answers in your operators guide, , here it is again,
im going for the record here...
short answer, NO YOU cant, you LOST it.
med. answer, have post from guy that guessed 5000 time and won.
long below:
quoted 29 times now:
De'ja' vu , all over again. (LOL) RTM
RTM read the operators manual, its all there, here is a direct quote.
true for all cars, really all modern cars, 2001 to now. about. read your operator guide) (sadly my jeep has no backup method, max paranoia that)
2008 opr.guide.(lost it, huh?) Accord. non satellite Radio. NAV system has own code. , all cars.... 2008 direct quote.
Quotes:
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because there are hundreds of number combinations possible from the five
digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars'
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
Aug 04, 2013 | Honda Pilot Cars & Trucks
How to reduce the size of a color copy?
You will want to press the MENU button on your printer until the Change Copy Settings item appears. You will then scroll through that menu using the left and right arrows on your menu panel until you see the ENLARGE/REDUCE menu choice. This will give you 3 choices to enlarge or reduce your copy. There are Preset Ratio, ZOOM, or Fit To Page.
Preset Ratio has 2 different sizes you can choose.
Zoom allows you to choose from 25% to 400%.
Fit To Page will automatically scan your image and then fir it to the size of page you have chosen to load into your printer.
If you haven't already done so you can go to the following webpage:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Choose the MP210 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000), the actual link is called "mp210sosmwin110us.exe". Clicking on that link will allow you to download the file to your desktop. Then double-click the icon and your manual will automatically unpack and install itself. You will then see an icon on your desktop called MP210 series On-screen Manual. Double-click this to load the actual manual. Then choose User Guide. When the User Guide loads choose Changing the Copy Settings under the Copying heading on the left hand side. You can then see a detailed description of the information I gave you in this answer.
This should let you do your adjustment but if not please let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 15, 2011 | Canon PIXMA MP210 InkJet Printer
Recording
Heres is the manual for the 200 series look under page 10.
http://www.sandisk.com/Assets/File/Downloads/user-guides/80-36-00556.pdf
Hope this helps. M~
May 03, 2008 | SanDisk Sansa c240 MP3 Player
Need manual for VCR
Google it. "Manual Sanyo H793" Or try using common sense and insticnts to guide you to do it yourself. You know, its usally the same, menu, presets auto manual , up-down. Or if its old there is uaually a whitr screw at the back which you turn to tune on each preset. :-)
Jan 04, 2008 | Televison & Video
37 people viewed this question
 Grubhead
Grubhead
