Error message on my samsung TV unable to decode HD
Hi I have a Samsung LA 26R51B LCD TV and the above message comes up when I try to get a HD channel. I have a Panasonic DVD recorder model DMR-EX75 and a TEAC HD-B820 Set top box can you please help me
many thanks Lance
have a nice day
5 Suggested Answers
SOURCE: I've lost (!) the digital
See if you can find it here: http://tinyurl.com/5bxn7q
Posted on May 11, 2008
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
taran_2005
  • 10515 Answers
SOURCE: Panasonic DMR-EX75 EB-S 160Gb DVD
To my knowledge and on most Panasonic UK/Euro models/versions, error code "U81" indicates glitch in the firmware, specifically, on its initial diagnostic mode, the system could not detect "Freeview" signals. The concern might have been caused by the absence of an incoming TV signal. Should this hold true, I then suspect that there is nothing wrong with the Panasonic unit but rather the Freeview service in your location or configuration/settings of the provider signals or the tuner.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 16, 2010
  • 11800 Answers
SOURCE: I can tune my Panasonic
The actual HD channels use a different data coding system than SD channels. The device that is used to receive (the Panasonic if the cable plug into it and the tv is connected thru the AV cable or the tv itself) it doesn't have the capability to decode them. This is something that cannot be changed, it's a hardware limitation.
The only way to change that is to use an external tuner/decoder. If you want to record only what you see and nothing else then a new model of a HD recorder is needed. If you want to view a channel while the recorder records another then you will also need a HD tuner, to which the tv will be connected the AV way.
Posted on Dec 28, 2010
I have a luxor 32" lcd tv and i cant get my surrond sound speakers to work. how do i do this?
Hi well surround sound speakers require an "Interconnection" box, that is a box with Jacks that the Red & White stereo audio plug into, on one side, and the 3 SS speakers plug into the "Other side" as it were. Usually with SS we have a Rear, Front and Sub Woofer, as this means 3 sets of speakers must mate with the 2 outputs from the TV etc. So the "Line Out" stereo output from the TV, which are usually the Red & White, is the output to the interconnection box, from there it feeds into the SS decoder, some plug directly into the decoder itself, and don't use an interconnect box, but it's all the same in the end. The stereo output is fed into the SS decoder, and then SS signal is extracted from the sign in, and routed out to the appropriate speakers.
Oct 21, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a Samsung LE26R8 tv which is HD ready, It has built in freeview will i get HD channles or will i have to get a HD tuner
Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
Jul 24, 2011 | Televison & Video
Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Apr 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
Add subtitles samsung
Must tries mutilple channels,pushes the remote button CC 1,2,3 on every channels.Sometime channels don't have captioning.
Feb 24, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Dec 06, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung le40r74bd LCD TV
hi is the power still coming on? if yes no need for power . have u put anntenal & change the chanels b4 then to see if sound will come .if ye s its yuor backlight inverter u can also disconet ur inverter plug & power on  the tv & change channels if works change ur inverter if dead change your ad or mainboard .
for replacement , lcd parts .com. will help
Nov 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
291 people viewed this question
Top Televison & Video Experts
