Question about LG WM-2277HW Front Load Washer
New LG Washer Dryer
Have AE error code
  • eyudmaowp May 09, 2008
    We are also getting an AE error. According to the booklet this means "water leaks" - but there are no leaks at all. Does anyone know the answer? We've carried out all the usual maintenance, drain not blocked, no excess detergent, no filter blocked etc.
    Thanks
  • 489 Answers
Are you sure it's says AE for the error code.  LG doesn't list that particular error code.  Please check again.
Posted on Apr 27, 2008
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: How do i fix error
Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
Posted on Aug 28, 2011
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
LG Inverter Direct dishwasher shows AE and sounds like it's trying to run
The LG Support page has a Troubleshooting Guide for the AE error code and suggests it may be too much detergent being used.
Here's the link.
LG Help Library AE E1 ERROR CODE DISH WASHER LG
May 08, 2018 | LG Dishwashers
Lg AE code
The AE error is
indicative that there is a leak
somewhere in the washer and it has
triggered the flood protection device
found at the bottom of machine.
For more information check the LG site: http://www.lg.com/ae/support/product-help/CT20076045-1442052868665-other-error-codes
All the best and Happy new year !
Dec 29, 2017 | LG Washing Machines
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
I have a e ae please help
Good Afternoon Dan, thank you for your post!
Are you certain the error code is E AE? Is it possible that the error code is missing characters? According from my research EAE is not a valid error code. Meanwhile, let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the washer on. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display E AE? With this information I can better address the issue at hand. Thank you!
Oct 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do i fix error code AE on LG washer/dryer f1407adsp5
Hi.
Regards.
Ginko
Aug 28, 2011 | LG WM-2277HW Front Load Washer
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
Ae display warning
Hi
Error AE means that the machine has detected a leak in the base of the washer. The anti flood device has detected the water and its displaying the error AE.
Unplug the washer and remove the back panel of the washer. Check for any stagnant water present in the base of the washer. If no water is present then check for the anti flood sensor and any disconnected wires.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | LG WM-12120BD Front Load All-in-One Washer...
LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
FAULT CODE
AI got here after googling the same problem.
There are many reports of this "dHE" error - all with BRAND NEW MACHINES !
I rang LG in Sydney, Australia today and amazingly the girl on the phone said there are no known issues with this dryer
(In Australia the combo dryer is known as WD14700RD ) - 7kg washer / 4kg dryer.
Mine has same problem. Whenever the dryer is selected in the program, it stops after the wash phase and flashed dHE (or dHe, can't remember) and thats as far as it gets.
Its a tech, call out tomorrow to try & fix it.
Very poor LG, these are brand new machines, many reports of this problem from googling it but LG have no knowledge a problem.
This may end up being a recall or at the very least, some public announcement of this dHe problem with this washer.
New buyers beware ... It is a fault with brand new machines.
Steve
Melbourne Aust.
Sep 23, 2007 | LG WD-12126RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
1,674 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
