My hauzen air conditioner run but no cold air comes out
hotuna
  • 288 Answers
SOURCE: Coleman RV Rooftop Air conditioner
If the compressor is tripping the breaker, then its 1 of 2 things. First clean the coils and change the air filter. If the coils are dirty and/or the filter is clogged, it will make the compressor overload and the high amp draw will make the breaker trip. If this doesn't solve the problem, you need to check the compressor itself. remove the connections at the compressor, leaving only 3 posts on it. You will need a meter to check for continuity to all 3. They should all have continuity to each other. While there check the wires. Sometimes a burnt wire will come off and arc on something causing the breaker to trip, if you are lucky.
Posted on Mar 02, 2008
Krazytech
  • 725 Answers
SOURCE: E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Posted on Jul 26, 2008
  • 10865 Answers
SOURCE: No cold air.
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
Posted on May 26, 2009
bobicehouse
  • 1524 Answers
SOURCE: the fan runs on the air conditioner but the
Try replacing the compressor capacitor.
Posted on Apr 09, 2010
heatman101
  • 43501 Answers
SOURCE: Friedrich QuietMaster SS08J10R Air Conditioner is not working
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Air conditioner blower won't run
need too check your orifice tub it could be colgged but make sure you check first your high pressure switch
Jun 18, 2014 | Lennox Armstrong Furnace Control Board...
Why is my air conditioner not blowing cold air
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FAC107P1A, comes on with the compressor running, but the air is not cold. First, check to see that the temperature sensing element, located behind air filter, is not touching a cold coil. If it is, straighten the element away from the coil. Secondly, try resetting to a lower temperature. Lastly, the compressor may have shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FAC107P1A Wall/Window Air...
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
The Ruud air conditioner is running but the house temperature is not dropping and we have checked that there is cold air coming out of the runs.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 24, 2011 | Ruud UAKA030 Air Conditioner
I have a hauzen wall (ducted) fan/air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an...
i have a hauzen air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an orange button to turn on and off... can you send me an english manual link? the wall unit is about 3 feet and also has a grey button on the right front bottom unit to turn it on and off. above that on the front right flat side are 5 small round lights that let you know how you have the unit set. hope this description helps you understand what kind of unit i have... i cannot read korean to be more clear. i would appreciate it if you can send a user guide in english. thank you
Jul 24, 2011 | Heating & Cooling
1.5 ton ac. It is getting cold near the outlet but cold air is not blowing out. Instead pieces of ice are sometimes coming out. How to troubleshoot?
Is the fan running? If the fan is running you should check your filter. If it isn't running then you should check the capacitor for the fan and the fan motor. Also make sure the evaporator coil is clean. If all of this is good then get the refrigerant charge checked.
Jun 06, 2010 | Samsung AW0503B Air Conditioner
Liquid line is cool coming from condenser indoor air not cold enough. Unit runs constantly at temps of 90 to maintain 80 inside
If the compressor is running at 90 there should be hot air coming out of the condensing units fan, if not it could be damaged valves in the compressor especially if the suction line is colder than normal like ice cold.
Obviously if the compressor is not running then you have other electrical problems.
Jun 02, 2010 | Bryant 463AAC005BA Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner fan is not moving air is coming from the vents but not cold
Air conditioner probably has a failed run capacitor inside the unit. Check all circuit breakers and/or fuses first.
Jun 30, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
