Brother IntelliFax-2820 Laser Fax Logo
Posted on Jul 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SIR I HAVE BROTHER 2820 I NEED TO INCREASE BEEP SOUND 5 OR MORE TIMES WHEN I RECIEVE FAX.
RAJKUMAR RAJU
Level 2:
New Friend:
  • Expert 116 Answers
  • Posted on Jul 11, 2010
RAJKUMAR RAJU
Expert
Level 2:
New Friend:
Answers
116
Questions
Helped
24439
Points
138
Go to menu,fax,ring delay, press 5 ,again press menu
1helpful
When i send a Fax how do i get a copy that the fax was Recived to the person i sent it to
You will get sound signal like longer beep. when you get three short beeps it means error (sent fax was not successful).
Also you can set XMIT report (means after every your sent fax, you will get printed out sheet with confirmation or error for previous sent fax - not recommended, will increase consumption of paper and toner).
If want to, follow steps:
- press key "Menu/Set"
- press "2" key
- press "4" key
- press "1" key (will see "trans: off")
- with navigation key "down" or "up" select "trans: on" or "trans: on + image"
- then press key "Menu/Set" to confirm it
Done
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
1helpful
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
1helpful
Brother Fax 2820 - The phone rings on it, but the fax come
Check if the machine is set on automatic recieve.
When on manual recieve, you'll have to start recieving manualy by pressing the button.
Can only recieve some faxes
this sounds like may be there is a phone line problem on those two machines or that line is there dial tone??may be you need to have local phone company check this out
16helpful
4answers
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
Brother Intellifax 2820 fax machine
Same thing happened to ours here at work except it was the #3 that got stuck. It was idle for 3 weeks because no one took the time to see what was going on. Five seconds on Google and 20 seconds on fixya.com and we have a working fax machine again.
Norman Weimar
Norman Weimar
k24674
