Question about Sony VAIO VGN-FJ180P Notebook
What are the buttons meant for in the sony vaio vgn-fj180p above the keyboard S1 and S2
    Novelist:
  • 112 Answers
S1 and S2 buttons are called special Function keys.
By default, the S1 button turns the Volume On or Off and the S2 button toggles the display between the LCD and the external devices. You can also change these buttons assignments on the window for changing the S button assignments. To display this window, press and hold either button or launch and navigate through VAIO Central (Start, All Programs, VAIO Central).
Good Luck!!!!
Posted on Jul 10, 2010
Fn keys working hotkey
Normally this issue happens after installing the a system related software or an upgrading/ reinstalling a operating system. Please read the below steps very carefully and follow the procedure below to resolve the issue.
Download and install the following application updates in the exact order they are given.
IMPORTANT:All of the listed application updates are available online. Software and driver updates for your Sony product are available online.
  1. Audio Driver (most recent)
  2. Video Driver (most recent)
  3. Sony Firmware Extension Parser Device Driver
  4. Sony Shared Library Update
  5. Sony Setting Utilities Update
  6. VAIO Event Services Update (If available)
  7. VAIO Launcher Software (S1/S2/AV Buttons)
If the above order does not work, try the order below.
  3. Sony Programmable I/O Control Device Driver Utility or Sony Notebook Control Driver
  5. Sony Utilities DLL Update
  6. Sony Event Service (If available)
  7. Sony AV Mode Button Utility (If available)
Reference: The function keys do not work
Jan 11, 2014 | Sony VAIO VGN-CR510E/L Laptop
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
My sony vaio cannot open, even battery is charging or plug in, i cannot power on the button? what is the problem please help... thank you
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Jul 16, 2011 | Sony VAIO VGN-FJ180P Notebook
My problem is once i open my webcam at yahoo messenger its appears "sorry no webcam was found on your system" can you help me my laptop is a sony vaio CR(VGN-CR23) thank you!!!
Google Sony Vaio CR (VGN-CR23) webcam driver and try reinstalling it. try to find a legit driver from the sony website. if not then download a third party one.
Hope this helps.
May 02, 2011 | Sony VAIO VGN-FJ180P Notebook
I need bios password
Remove the CMOS battery ,wait for 30 secends and and again start.
To disassemble follow the bellow links.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
http://www.laptopparts101.com/cmos-rtc-battery/
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
http://shopping.microbattery.com/s.nl/sc.2/category.763/.f?sendroicid=eb19116b-0e44-4ecf-b82d-e596f32a01ea&sendroikwd=notebook+cmos+battery&gclid=CN_DnuzolqYCFUUb6wodORuwLw
Hope it will help you.
Dec 31, 2010 | Sony VAIO VGN-FJ180P Notebook
Im in Vietnam and i have a Sony vaio VGN-CS215j/w but the touch sensor of volum can not use. Pls help me repair it!
The plus (+) and minus (-) volume control buttons on the touch sensor bar above the keyboard may not work properly if the touchpad driver is not installed properly.
The other buttons on the touch sensor bar, such as the play, forward, or rewind buttons, may still work properly.
To resolve the issue, download and install the original Synaptics® Touchpad Driver (or an updated version of that driver, if available) from the Drivers & Software link on this page.
May 20, 2010 | Sony VAIO VGN-CS215J/W Notebook
Sony vaio av mode button is stuck
You may disable the AV Mode feature from the VAIO Control Center Application.
The VAIO Control Center Application will be shipped with all the VAIO Computers which have the Windows Vista or 7 Operating Systems.
You may disable the AV Mode feature from this Application.
You may also disable much more features such as the Touchpad, Special keys(S1 and S2) etc, by using the VAIO Control Center.
Hope this helps.
Mar 09, 2010 | Sony VAIO M1 (VGCM1) PC Desktop
Webcam software for sony vaio laptop ,inbuilt webcam software of the sony vaio laptop VGN Fj 68 GP /w not working I cannot use my webcam because I don´t find an icon to click on. I think I must activate...
Check out the manual on your computer regarding the webcam controls
Sometimes the webcam start procedure can be found under the keyboard heading
Start > Computer >> Local disk (C) >> Documentation >> EN(glish)
Try the Sony Support website for drivers
http://www.kb.sony.com/selfservice/microsites/searchEntry.do?locale=LA_eng_US&usemicrosite=true&region=UMRE_UNITEDSTATES_2_5&sonyregion=US&searchString=webcam%20drivers&product=&sonytemplate=&sonymodel=
May 31, 2009 | Sony VAIO VGN-FJ180P Notebook
Vaio Screen blank
go to power setting and see if ur pc is set to sleep....if so change it....
u will find the power setting in control panel
May 17, 2009 | Computers & Internet
Sony VAIO VGN-FJ180P Notebook Logo
526 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
