Question about Friedrich QuietMaster Heavy Duty SL25J30 Air Conditioner
UNIT IS FREEZING UP - Friedrich QuietMaster Heavy Duty SL25J30 Air Conditioner
  • Friedrich Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Unit is freezing up
what type of gas?
if R410A it too low
if R22 check for inside air flow
Jun 23, 2012 | Gibson Nordyne/2 Ton Heat Pump Package...
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Making a fast beeping noise and is freezing up
Remove the connection to the drive unit and check if freezing persist.If not check drive motor and cable.
If freezing persist and compass is ok the control unit is faulty.
Verify if the compass reading is ok in four directions on standby.if not check compass or compass wiring.
Apr 26, 2010 | Raymarine St 4000 Wheel Drive E12093
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Sansa c250 constantly freezing
Hi
Try to scan with antivirus!!! maybe your unit is have a virus thats why your unit is freezing.
Thanks! Likha
Sep 20, 2008 | SanDisk Sansa e250 MP3 Player
Friedrich QuietMaster Heavy Duty SL25J30 Air Conditioner Logo
57 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
